2jz swap problem
Old 03-20-12, 07:46 PM
ogtony19
ogtony19's Avatar
Default 2jz swap problem
So this past weekend I swapped in a younger 2jzge that I upgraded with arp headstuds and a gte headgasket and now I can't get it to start. It cranks, has spark and can here the fuel pump and its priming but no turnover. It has a 4runner dizzy cap and the wires are plugged in right. I used the same wiring harness from the old engine and plugged everything back in. Only thing is that there is a male plug on the engine harness that I cannot find another female plug for. It is a 2 wire plug that comes from the part of the harness under the intake manifold and it hangs close to the brake booster. I'm open to any suggestions right now as I just want my baby to run again. And I'll try to supply any more info that is needed to help me sort this out.
Old 03-20-12, 07:53 PM
g4ebguy90
g4ebguy90's Avatar
Compression, make sure timing is good. Recheck all connections. Fuses.
In cases like this, its usually the obvious.
Old 03-20-12, 07:56 PM
ogtony19
ogtony19's Avatar
Everything was set to tdc, and I'll try to do a compression test. And everything worked fine before the swap.
Pfritts
14
05-07-19 11:59 AM
driftdan
09-29-15 11:29 PM
Dtaylor3
05-11-15 12:31 PM
Quick Reply: 2jz swap problem
