Engine leak - Can someone identify what this is? (PIC)
Subscribe
Feb 19, 2012 | 02:10 PM
I was checking the oil this afternoon and noticed what appears to be a leak on the engine. I snapped a few picture of what I saw. This is on my 1993 SC300 (115,000 miles)
It is at the front left of the engine, above and around what I'm guessing is the water pump.
larger pics of above:
http://dl.dropbox.com/u/9797219/sc300/IMG_8489.JPG
http://dl.dropbox.com/u/9797219/sc300/IMG_8488.JPG
http://dl.dropbox.com/u/9797219/sc300/IMG_8487.JPG
Anyone know if this is something serious?
Reply 0
Feb 19, 2012 | 02:43 PM
dist. o-ring is leaking, shield under the dist. is a dead give away. It's all covered in oil
Reply 0
Feb 19, 2012 | 03:05 PM
Quote: dist. o-ring is leaking, shield under the dist. is a dead give away. It's all covered in oil
Thanks so much for the reply. This doesn't look major. I can probably swap that out with a new one pretty fast. Is the replacement as easy as unbolt, add new, and replace, or is there a sensor I need to be concerned about?
Again, I really apreciate the help. I hope there isn't danger of riding on this for a week or so.... can't get time off till Friday.
Reply 0
Feb 19, 2012 | 03:17 PM
replacement is simply, just one bolt to remove the distributor. Make sure you mark the dist. before removal so you don't have to re-set timing (unless you can get a hold of a timing light)
Reply 0
Feb 19, 2012 | 03:28 PM
Quote: replacement is simply, just one bolt to remove the distributor. Make sure you mark the dist. before removal so you don't have to re-set timing (unless you can get a hold of a timing light)
Awesome. Thanks, for the help. I'll swap it out Friday.
Reply 0
Feb 19, 2012 | 03:50 PM
Isn't the o-ring a dealer only part?
Reply 0
Feb 19, 2012 | 04:02 PM
lol I got that leaking too, I'm lazing off fixing it in this doggone cold (its actually snowing today).
I think theres a pictorial diy on here too as well... check the diy directory
Reply 0
Feb 19, 2012 | 04:10 PM
Quote: lol I got that leaking too, I'm lazing off fixing it in this doggone cold (its actually snowing today).
Will do. Yeah, the ring is a seperate part.... I've seen it for cheap a few places online
These guys have it:
auto parts warehouse <dot> com - $3 bucks....
Reply 0
Feb 19, 2012 | 04:37 PM
Did I just type "too as well"??
Id check toyota dealership theyd have it cheaper than lexus dealer.
Reply 0
Feb 19, 2012 | 05:55 PM
Please use the proper forum for maintenance questions Moved.
Reply 0
Feb 20, 2012 | 02:30 PM
distributor o-ring and/or valve cover oil leak.
Reply 0
Subscribe
