Am I screwed?... :-(
Old 12-30-10, 09:10 AM
BrownGuy
BrownGuy's Avatar
Default Am I screwed?... :-(
I recently got a deal on a 1jz stock setup for a good price and instead of just throwing it in the sc i wanted to re do all seals and get the head cleaned and resurfaced, so naturally i tore the motor down took off all belts, covers, etc. Although I have some engine mechanical knowledge, this is the first time i have worked on a 1j like this taking off the head to change a head gasket. I noticed that on the cam shaft brackets there was a lettering sequence and didnt think nothing of it at the time....now i am wondering.....did I need to remember that sequence for the reinstall? And if so am i screwed if i dont remember what it was?
EDIT: did a search and found a diy for the head uninstall.... but nothing on the reinstall....
Old 12-30-10, 09:23 AM
LexusFTW
LexusFTW's Avatar
Those brackets are the cam caps and yes, you need to put them in the exact order. They are numbered and also lettered for intake and exhaust. Good luck.
Old 12-30-10, 09:24 AM
stockhatch
stockhatch's Avatar
You should have noted the position of each cap. You can take it to a machine shop and have them sort the caps with a bore gauge. Otherwise it is a guessing game and you will inevitably end up with a cap that is not aligned 100%.
Just my .02 on the RIGHT way to do it. You could also just slap them on there any old way and cross your fingers.
EDIT: Oh cool, I did not realize they were all numbered and lettered appropriately. I did not really notice that when I took mine off. I did see some letters, but nothing that seemed to be too meaningful regarding position. I stand corrected.
Old 12-30-10, 09:37 AM
BrownGuy
BrownGuy's Avatar
thanks guys. i almost **** a brick when a buddy of mine told me that i can lose oil pressure and what not if i dont put them back in the EXACT same order. but he works with RBs so different tech.
Old 12-30-10, 09:42 AM
mak89
mak89's Avatar
was it Jeff's DIY btw??
Old 12-30-10, 09:45 AM
BrownGuy
BrownGuy's Avatar
If Jeff is silent1pro then yeah.
Old 12-30-10, 11:11 AM
TLDriver
TLDriver's Avatar
Did you remove the buckets from under the cams? if you did... you will have to re-shim it and find out what bucket goes where. I F'ed up and now had to pay someone to do that for me.
Old 12-30-10, 01:25 PM
99SC42
gte & na-t
99SC42's Avatar
Lol it's really easy they have letters and number on them clean them up really good and you will see.
I1,I2,I3,I4,I5,I6,I6 those are the intake side
E1,E2,E3,E4,E5,E6,E7 those the exhaust side.
Just clean the top of the cam cap and you will send the letter I or E and the number and then there is an arrow that shows you what side suppose to face the front of the engine.
Old 12-30-10, 03:44 PM
5sp_jzz30
5sp_jzz30's Avatar
^^^this
pretty much all toyota motors use numbers on the caps. only way to put them in the wrong spot is if you're blind.
Old 12-30-10, 03:45 PM
Ali SC3
Ali SC3's Avatar
I didn't think you could still wow me after all the work weve done but there you go again
Old 12-30-10, 08:04 PM
SC51
SC51's Avatar
quickGS300 Lol it's really easy they have letters and number on them clean them up really good and you will see.
Really good input
Old 12-30-10, 08:13 PM
meangreen1
meangreen1's Avatar
It's always a good idea to take pics before you take anything apart.
Old 12-30-10, 08:49 PM
BartleDoo
BartleDoo's Avatar
Nonsense! But I also think it's cheating to use the picture on the box for reference when doing a puzzle.
Old 12-30-10, 10:10 PM
TLDriver
TLDriver's Avatar
Too easy to make a joke out of.. LOL
Old 12-30-10, 10:30 PM
94_soarer
94_soarer's Avatar
He is absolutely correct...I jus helped my buddy put Brian Crower 264 cams in his Rhd Mkiv supra
Quick Reply: Am I screwed?... :-(
