1jz Throttle Body Question
Old 07-01-10, 10:14 PM
SC2JZ300
SC2JZ300's Avatar
Default 1jz Throttle Body Question
I have a 1JZ throttle body that is equipped with a secondary throttle blade and motor, which is part of the vehicle's optional traction control system.
Now my question is can the secondary motor be removed and capped off or should I replace the entire throttle body with a soarer one.
Or if there are any other options I can go with thanks.
Old 07-02-10, 02:06 AM
v8soarer91
v8soarer91's Avatar
on mine i have used a bung and had it welded.
then used an air sander, 2000, 3000, metal polish.
Old 07-02-10, 03:25 PM
SC2JZ300
SC2JZ300's Avatar
Did you do both sides?
driftboy
SC400 / 300 Classifieds
08-12-11 02:14 PM
WetLexus
06-15-11 08:58 PM
1985zcar
11-01-08 03:37 AM
Quick Reply: 1jz Throttle Body Question
