DIY. Alternator Fuse.
Old Apr 9, 2010 | 09:02 PM
SpuGen's Avatar
SpuGen
Default DIY. Alternator Fuse.
Electrical problems, no dash lights, no power, dead alternator, etc.
Replaced the alternator and new battery, and your car still doesn't work?
It's this.
Tools needed:
8mm Socket
10mm Socket
12mm Socket
13mm Socket
Small Flathead screwdriver.
150A Fuseable link from Lexus. $23.41 Canada price.
- Remove the positive terminal from the battery. 10mm
- Take off the cover on the fuse box under the hood with a flathead
- Take off the 2 10mm bolts holding the fuse block.
- Use your fuse box cover as a bucket to hold your nuts / tools.
- The Fuse block has 2 sections. Use the small flathead to pry the 2 tabs and seperate. Be careful, they're fragile.
- Pull the smaller section up. Remove the bolts as pictured with the right sized sockets as listed.
- Take it out. Replace.
I have ugly fingers.
Old Feb 14, 2011 | 06:23 PM
waldrgd's Avatar
waldrgd
I have a RX 350 with the alternator fuse blown. I can't seem to be able to get it out or take the box apart. It is buried deep in the box. Can you give more detail as to how to take it apart? Thanks
Old Mar 18, 2011 | 12:03 PM
SpuGen's Avatar
SpuGen
The Panel should be held on by some 10mm bolts. After you remove those, there are clips holding the 2 sectional panels together. Take a flathead to it, and the panel itself should be free to move around. After that, the fuseable link is held on by a 12/10mm.
This was on a 95 SC400. So I don't know if it'll be the same for you.
Old Mar 18, 2011 | 05:47 PM
iwannadie's Avatar
iwannadie
You should remove the negative battery cable not the positive.
Old Sep 27, 2013 | 11:13 AM
crrc5508's Avatar
crrc5508
Just know the whole plastic piece comes off so you can get to the bolts. I unbolted all the top screws on top. but now realize I may have been able to pry just the front part of the front plastic case off. You have to know the bolts to the 150 amp fuse is not just on the front part, but there is another bolt on the back, so you can get to it after you lift the front part of the plastic case.
Old Mar 21, 2014 | 11:59 PM
iridebmx's Avatar
iridebmx
for reference the part # to this fuse is:
90982-08272
Old Aug 1, 2017 | 03:04 PM
Flex400's Avatar
Flex400
Default Fusible link part # correction
Hi all,
Thanks for all the info on this. Couldn't figure out why my electrical systems went down and also...explain why my battery kept draining.
I at some point blew the 120a fusible link and thus I had to keep charging my battery/jumping to get the car to start.
This is probably why driving the car around didn't charge the battery.
Took me a while to find this helpful post and wanted to share some info:
The Lexus part number provided: 90982-08272
Is for a 150 amp fusible link - called Lexus of Oakland, CA and that's what they told me - the ls400 is a 120 amp fuse though
I told them I had a 1990 LS400 and needed that alternator fusible link and they said the part number was:
90982-08254 for the 120 amp fuse - they checked and that was the part number for the 90 ls400
I asked if there was an equivalent Toyota part number (usually the parts are the same between Lexus/Toyota but the part numbers may be different)
she said it might be the same, call Toyota and ask.
Toyota of Berkeley quoted me $17 for the same part and they'd have to order it - Lexus quoted me $14 for the part and they had it in stock
so in this rare case Lexus was cheaper - maybe the fuse has been sitting there since 1990.
I checked all my regular blade fuses, nothing blown, and those three round things that you insert a pin into to reset - breakers i think...nothing.
Upon super close inspection the stupid 120a fusible link was blown.
I'll have to pick up the fusible link, take the fusebox apart to install it and see what happens.
Unfortunately my car is at my friends so I'll have bring my tools and service manuals over.
I'll let you guys know how it goes.
Old Jan 19, 2025 | 11:12 AM
gjonesgrad's Avatar
gjonesgrad
3rd Gear
What happened with this? Did replacement of the Alternator 120A fuse work? I have a 'new' alternator that is not putting out anyting to charge my new battery.
Thanks,
Old Feb 19, 2025 | 06:31 PM
Denvergal's Avatar
Denvergal
2005 ES 330
Checking the fuses first has saved me A LOT of money. My speakers went out and I only had to change the fuse. Other people said you had to replace some woven cable in the trunk, huge pain. I read the user manual and the speakers were listed under the fuses.
Love saving money through a little research.
HyadMusic
Jun 24, 2014 10:21 AM
us261613
Oct 11, 2010 09:41 PM
NickiM
Dec 15, 2008 09:26 PM
UptownGS
Nov 15, 2004 09:38 AM
sxyskier72
Nov 8, 2004 10:17 AM
