1jz running problems!!!
Old 02-05-10, 12:10 AM
GSXRMack
GSXRMack's Avatar
Fix the problem you know is 100% there--No O2 sensor then go from there. If you don't have one or planning wideband. Get an Innovate LC-1 deals all over ebay with a gauge. read about it. Wire it in and it will also act as your stock sensor to the ECU and wideband to the gauge.
Then if it ain't right go from there.
Reset battery-Pull EFI fuse for a while, or pull the battery cables off.
Old 02-05-10, 11:22 AM
Yahoo27
Yahoo27's Avatar
My car didn't want to start randomly also, once it will start and run fine, it would not start sometimes, and some time kinda start and run like crap..... It was my CTS (coolant temp sensor) for the ecu made it not start, the sensor went bad and didn't read right sometimes. And for the noise it sounds like you did the 12v mod???
Old 02-06-10, 12:18 AM
got-sc?
got-sc?'s Avatar
i have a wideband the aem UEGO and im going to install it, but the signal wire will be going to the greddy emanage ultimate which i will get soon (from ryan_v). So if the signal wire is going to the emanage will the ecu still read it???
Old 02-06-10, 02:28 PM
GSXRMack
GSXRMack's Avatar
I am not sure about the AEM but hte LC-1 has wires specifically for the ecu and separate for the gauge and emanage. Maybe yours can do that too.
Old 02-08-10, 11:32 PM
got-sc?
got-sc?'s Avatar
ok i checked everything and tried a different igniter and still same problem. Any suggestions, next thing im going to check is ECU
Old 02-09-10, 12:50 PM
got-sc?
got-sc?'s Avatar
opened up the ecu and saw no capicitors leaking, can an ecu be "done" or "toast" with no signs of anything burning or anything leaking?????
Old 03-31-10, 02:00 PM
got-sc?
got-sc?'s Avatar
Ok i thought it was fuel pressure regulator but its not. installed an aftermarket one and as i adjusted it psi went from 10-30psi every half second. ANY IDEAS???
Old 04-01-10, 09:05 AM
soarer479
soarer479's Avatar
have you checked the fuel pump itself? if you often run a pump low on gas it can burn up or damage the pump. also what pump are you running it sounds to me like a lack of fuel issue
Old 04-13-10, 07:08 PM
got-sc?
got-sc?'s Avatar
ok i guess its a bad ecu. the owner of the shop is going to rebuild it for a good price. the ecu isnt giving signal to the ignitor or injectors
Old 06-14-10, 06:57 AM
TASOARER
TASOARER's Avatar
Any Update?
Old 04-16-13, 04:59 PM
Uhhhsc300
Uhhhsc300's Avatar
I just had a bad ecu also it misfired real bad and couldn't figure it out. Tried a new e u and it worked
Old 04-16-13, 07:04 PM
kez
kez's Avatar
Ahhhhhh it's a zombie thread
Old 02-24-15, 03:49 PM
Tommy150
Tommy150's Avatar
i know this thread is dead, but for any one running around with this issue. my problem was that the coil pack clips where loose. its a know thing with the clips going brittle from old age.
Old 04-07-15, 05:39 PM
yauny
yauny's Avatar
Default same here
I've went through alot of things and still can't figure this out but I have hallowed out my cats because they were clogged but the o2 sensors are still there but it feels like my cars running rich which im assuming is because of no cats but when I get up near 2-3k rpms it start to jerk and seem like its not getting enuf fuel plus it kicks like a mother and at 60 mph it seems like the car doesn't want to shift into fourth or third I dont kno what gear it should be shift in in at those speeds. Changed all injector conn. Fuel filter cam sensors and still can't figure it out. Any help would be awesome thanks in advance
ChrisPacki
Maintenance
01-23-14 08:20 AM
1jztts
01-16-14 08:38 AM
michael63
10-18-11 11:35 PM
Cletus
SC- 1st Gen (1992-2000)
10-06-10 11:25 AM
Quick Reply: 1jz running problems!!!
