Manifold niose (need advice)
Old May 13, 2002 | 09:57 AM
jersey1's Avatar
jersey1
Unhappy Manifold niose (need advice)
has anyone had a loud noise problem from the manifold and
is that a common problem. is a gasket leek or do i need to replace the manifold and if so do anyone have a used one and how much is it.
Old May 13, 2002 | 10:53 AM
Lex Luthor's Avatar
Lex Luthor
intake? exhaust?
Old May 13, 2002 | 11:04 AM
jersey1's Avatar
jersey1
Default parts
do you have anything else for and 94 sc300, what about a 98-99 front bumper, skurt, wing and chrome factory wheels and what part of NY are you from
Old May 13, 2002 | 08:01 PM
awj's Avatar
awj
Bluegr*** Performance
Hell's kitchen.
You will need to replace all of your manifolds. Sorry.
Old May 14, 2002 | 07:48 AM
jersey1's Avatar
jersey1
have you experienced this problem before? and why do you
say all the manifolds have to be replaced, and what does that cost
Old May 14, 2002 | 07:56 AM
awj's Avatar
awj
I'm sorry man, I was messin with you.
You have a 94 sc300 correct? You are hearing a noise. More information is needed. What makes you think it is coming from the manifold? Which manifold are you referring to as Lex asked? Is the car running smoothly?
Old May 16, 2002 | 08:27 PM
SC300T's Avatar
SC300T
What makes you think its a manifold?
On the exhaust side, a bad one could sound like a tick, but other than that, a bad gasket on either side is just going to make the engine a little louder...
Could you have a water pump, belt or accessory like power steering pump or A/C compressor making noise?
Old May 17, 2002 | 07:03 AM
Lex Luthor's Avatar
Lex Luthor
Actually, Brooklyn, but not too far from Hell's kitchen , but I moved to Lindenhurst not too long ago, easier to fall asleep with no L train or gunshots through the night. Yeah, like Scott said, an exhaust leak is like a tic-tic-tic, not too likely your intake manifold is leaking, but to check, spray something aerosol around the base of the intake and see if it changes anything, if there's a leak it will plug it for half a sec and the sound can change, the idle may change for a sec, etc, but like SC300T said, more than likely it's one of the accessories. So where you from tuff guy?
Old May 17, 2002 | 08:08 AM
jersey1's Avatar
jersey1
Default manifold
Could you have a water pump, belt or accessory like power steering pump orA/C compressor making noise?
Thanks for you advice bro but it ony cost me $200, the bracket that holds the manifold was broken, but im fine now.
djeddieo
RX - 1st Gen (1999-2003)
Aug 21, 2015 05:49 PM
DMPesso
Mar 14, 2014 08:31 PM
shammi5
Oct 25, 2013 07:49 PM
electro992
Apr 15, 2004 02:19 PM
