Sc400 Single T70 Turbo and 5speed conversion =)
Old Jan 31, 2011 | 09:14 AM
  #211
good2go's Avatar
good2go
Originally Posted by CarlosR347
Hey Guys Sorry I havent had time for anything ive been really busy with school.. I decided to do the HG, when i began taking the engine apart i found oil in the water So the HG was definately the over heating problem my god its been some work lol.. Anyways once i had the heads off and were at the machine shop they seemed pretty warped.. but now theyre FLAT =).. and I Have a Set of Cometic 0.51" MLS which i plan to eaither spray paint with aluminum paint or Copper spray from Permatex and 10mm ARP Studs from Lextreme ready to install, Im waiting to borrow a torque wrench from a freind to start.. oh and ima go ahead and swap out the motor mounts now that its just a shortblock sitting in the car.. hope this set up holds up to 17ish psi??
Yep, a half inch HG ought to drop your compression right down there
(sorry to hear about your HG issue, hope it wraps up ok for you after this go-round)
Old Feb 13, 2011 | 04:23 PM
  #212
CarlosR347's Avatar
CarlosR347
LMFAO!! my BAD! i meant to say 0.051".. haha a half inch gasket the intake wouldnt bolt up..
Old Feb 13, 2011 | 04:38 PM
  #213
CarlosR347's Avatar
CarlosR347
Originally Posted by MMCtuner
"Sorry" to hear that. Lol! With 17psi you´re gonna have a weapon there Carlos! With a T88 on stock engine, Adam made 394rwkw. About 530hp at the crank. Insane. Maybe with the new power you´ll convince to keep it. Don´t you think? =)
BTW, I´ve ordered the F/IC without the harness. Would you please share with me your wiring diagram?
Kind regards and good luck with the new mods.
yup i think i have an intake valve thats staying open =/ i shouldve listened to my dad and done a valve job, i ran a compression check on the left bank and all came in real low, right bank shows 180+psi.. I never have time to work on it and if i get the fulltime job before i get it running im going to sell the whole car.. i go to school from 6am-2:30 and work would be from 4-midnight.. it would be pointless..
Old Feb 13, 2011 | 04:43 PM
  #214
CarlosR347's Avatar
CarlosR347
I sure as hell hope so man, I really want to get it going, and I have your diagrams drawn out already i have it saved in my school computer Ill post when i get the chance this school year has been sooo busy
Old Feb 22, 2011 | 01:50 AM
  #215
CarlosR347's Avatar
CarlosR347
Valve.job complete.. head is on.. I'm firing this sucker up today around sunset!! >=]
Old Feb 23, 2011 | 05:19 PM
  #216
MMCtuner's Avatar
MMCtuner
Yeahh!!! Kudos to that Carlos! BTW, my AEM F/IC didn´t arrive yet
Old Mar 5, 2011 | 01:10 PM
  #217
MMCtuner's Avatar
MMCtuner
Yes! I´ve receive the F/IC! Now it´s only about time for my turbo build
Old Mar 10, 2011 | 12:55 PM
  #218
mustang024's Avatar
mustang024
Carlos great build man, once you get all the kinks worked out she will be a beast!!
I have a few questions about the turbo you have. Is that an Ebay T70 and if so is it a T3 or a T4?
What are the specs compressor housing/turbine housing A/R.
Do you know the inducer/exducer on both wheels??
When do you hit full boost and how much psi ?
Who was the Ebay seller if this infact an Ebay turbo?
Once gain man
Old Mar 10, 2011 | 03:02 PM
  #219
MMCtuner's Avatar
MMCtuner
It´s an Ebay T70 T3. For other specs you´ll have to wait for Carlos.
Old Mar 13, 2011 | 11:28 AM
  #220
CarlosR347's Avatar
CarlosR347
Once gain man
its a AR.70 Cold and .63 T3 Turbine it hit full psi (12psi) around 3.7k
Old Mar 16, 2011 | 12:27 PM
  #221
CarlosR347's Avatar
CarlosR347
Default On the streets!!
got it running on 8psi at the moment gonna turn it up to 10 today we took it out to street tune it =) this was a 1st and 2nd gear pull i think it has the stock exhaust from the middle back all you can hear is the engine!! it whistles nice too i love hearing it spool.. we took it on the highway and raped a G35 on a 70 roll with a 3 car length advance that same night lol.. i need to open up the exhaust cause its running a bit hot like halfway to 3/4 i think because the stock system is causing back pressure on the turbo and that i need to vent my engine bay some how im thinking about adding a scoop under the engine to scoop up cold air and a flap near the rear of the engine like on aircraft they use Cowl flaps which pretty much produce like a venturi effect between the bottom of the car and the pavement creating a lower pressure and extracting the hot air... any comments?
Old Mar 16, 2011 | 01:44 PM
  #222
MMCtuner's Avatar
MMCtuner
Let me know if I understood. You are using the stock exhaust but only one side, right? Or you re-attached the exhaust in the middle?
The stock exhaust it´s very restricted for a stock engine, I thing you should change the system soon by allowing it to flow. And buy a better phone =)
Old Mar 18, 2011 | 01:23 PM
  #223
CarlosR347's Avatar
CarlosR347
LOL nah my phones good the camera man is horrible.. I changed the exhaust yesterday I had the back half of the stock exhaust attached.. now its pretty much 3.5" from the turbo outlet to the back seats then a single straight 3" to a 3" straight through muffler, it sounds great! and it dropped the temperature ALOT.. It also spools up way faster im driving the car and it wants to boost on its own lol.. i need to refine my tune its rich right now.. now i just need to vent the heat out of the engine compartment.. to drop the Temperature a bit more.. this is the last video before we changed the exhaust i gotta make a new one with the new exhaust.. oh and MMC Tuner send me ure email so i can email you the diagrams
Old Mar 22, 2011 | 05:56 PM
  #224
CarlosR347's Avatar
CarlosR347
Old Mar 23, 2011 | 09:31 AM
  #225
MMCtuner's Avatar
MMCtuner
Mean sound!
Nice, very nice.
What´s next Carlos?
