low budget dual full pump
Old Oct 5, 2009 | 07:41 PM
demon2jz's Avatar
demon2jz
Default low budget dual full pump
[/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG[IMG][/IMG][/IMG][/IMG]
Old Oct 5, 2009 | 07:50 PM
1siksc's Avatar
1siksc
Very nice! I'm use to seeing zip ties. lol
Old Oct 5, 2009 | 10:18 PM
76mmturbo's Avatar
76mmturbo
did you tee the two pump together and weld a bulk fitting?
Old Oct 6, 2009 | 08:07 AM
LexusFTW's Avatar
LexusFTW
Good luck getting that in the tank...
Old Oct 6, 2009 | 11:38 AM
demon2jz's Avatar
demon2jz
both fit with no problem inside the gas tank imma post more pics later[IMG][/IMG]
Old Oct 6, 2009 | 11:42 AM
demon2jz's Avatar
demon2jz
its real easy to do it for me[IMG][/IMG][/IMG]
Old Oct 6, 2009 | 12:17 PM
SHOLEXMAN's Avatar
SHOLEXMAN
CL Folding 25,000
Nice lol... I have never seen that before.That pump on the left side has seen better days. make sure that thew wires are covered up extra cause the seat runs right on it and may wear them down after time. Might cause a spark leading to a fire blah blah blah....
Old Oct 6, 2009 | 02:38 PM
LexusFTW's Avatar
LexusFTW
good work. are you sing submersible fuel injection hose?
Old Oct 6, 2009 | 03:20 PM
ConSynX's Avatar
ConSynX
i'm confused about what happened with the wiring here. . .
Seems people are able to wire a second pump easily, but when I did mine I burned out a wire, hardcore.
Old Oct 6, 2009 | 04:14 PM
demon2jz's Avatar
demon2jz
yeah you need a submersible fuel hose
Old Oct 7, 2009 | 05:51 AM
motorheaddown's Avatar
motorheaddown
Sorry about the crappy pic, but here's another way to do it with worm gear clamps and gas tank filler hose to isolate the pumps from vibration.
-scott
Old Oct 10, 2009 | 07:15 AM
demon2jz's Avatar
demon2jz
[IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][IMG] [IMG][/IMG]
Old Oct 29, 2009 | 10:22 PM
dejacky's Avatar
dejacky
NIce setups. I'm curious, do you know the melting point of those zip ties you used to secure the fuel line under the car?
Old Oct 30, 2009 | 07:25 AM
TheRonTom3's Avatar
TheRonTom3
god the words "low budget" and "fuel" just shouldnt be used in the same sentence
Old Oct 30, 2009 | 08:12 AM
cbrasian's Avatar
cbrasian
doesn't really matter they will stay there and not melt off lots of people use zipties to route the fuel line than to drill screws for clamps I've had mine ziptied for 6 years and not one broken yet
Alex2JZSex
Dec 18, 2023 08:49 AM
lexforlife
Feb 28, 2012 03:41 PM
chuckb
Jul 17, 2006 09:30 PM
