hesitation
Old 07-28-09, 11:53 AM
brazil
brazil's Avatar
Default hesitation
I just bought a 95 sc400 with 200,000 miles on it in the morn if i try and drive the car before it is warm it doesnt wanna go, and now if i am around 25 mph it is very sluggish but as soon as i push on the gas it clears up any hlp would be nice...
Old 07-28-09, 07:07 PM
over40driv
over40driv's Avatar
It seems like 95 SC4s seem to have a low throttle position hesitation. Ive got a full tune up and new cat. conv., cant seem to get it comp. cleared up. I recommend all filters, plug wires and plugs. Be prepared when doing the fuel filter.
Old 07-28-09, 09:55 PM
brazil
brazil's Avatar
yeh i changed the fuel filter today too it didnt hlp but i also put on a cone k&n air filter and it seems like it got worse unplugged the mass sensor and the car drove perfect but i got a check ingine light so im gonna change the mass air sensor now ..
Old 07-29-09, 12:48 AM
AyDee
AyDee's Avatar
It does not have to be the Mass Air Sensor - when u disconnect your AFM all what you are doing is make your ECU run in safe mode - meaning it is sending an air-fuel mixture dependant on the RPM and other PHYSICAL factors not electrical signals from sensors
before you try the AFM, try to replace your Engine Coolant Temperature sensor (20 dollars) and see where that gets you. there is a thread on how to test your AFM to see if it is working.
search a little more there is a handful of people having the same issue you are having, including myslef
Ali
Old 07-29-09, 04:55 AM
brazil
brazil's Avatar
Ali
where is this located.
Old 07-29-09, 09:11 AM
AyDee
AyDee's Avatar
where are the threads or the ECT? be more specific with ur questions please
Old 07-30-09, 06:08 AM
brazil
brazil's Avatar
wow took the k&n filter off and put the factory air box bck prob solved car runs like its brand new now..
Old 07-30-09, 12:51 PM
AyDee
AyDee's Avatar
interesting
AyDee
AyDee's Avatar
did u have an after market air filter? did you replace the entire air box or just the filter?
Old 07-30-09, 02:09 PM
Ali SC3
Ali SC3's Avatar
he probably had a cone or a bfi that wasnt sealed.
these cars work best with the factory CAI or a eealed BFI.
putting a cone filter without a turbo is decreasing power for sure.
Old 07-31-09, 05:03 AM
brazil
brazil's Avatar
I had a k&n air filter with the housing but when u look threw the addapter that bolts to the factory mass it looked smaller and maybe the sensor wasnt reading the right amount i dnt know but im just gonna do the bfi..
Old 07-31-09, 02:26 PM
over40driv
over40driv's Avatar
Bought 2 dist. caps and rotors from Lex. today for my car. Only a few dollars more than the parts house. I am a mechanic and do get some discount.
Johnhav430
05-25-18 04:28 AM
qha_vn
16
04-24-16 09:51 PM
giolex300
04-12-12 10:56 AM
engin_ear
Performance
117
05-29-11 11:32 PM
marcmindte
02-12-07 08:43 AM
Quick Reply: hesitation
