Why a 1JZ-GTE?
Amen, brotha. I must say my 1jz has been more reliable then the 2002 Acura TLS I had with 3 blown transmission. The SC left me stranded only once in the 2 years I had it and that was because of a loose battery cable. I am trying not to modify mine to the point of unreliabilty.
Hmm.. Well Im definitely more comfortable now; and I think I'll go'head and do the swap.
Especially 'cus the 1JZ is only around 60,000 Miles compared to my nearly 200,000 Miles currently.
If I can switch to single turbo in the future, & have 600Hp, while in the mean time be around 300+ more easily.. I can live with that; and I think the journey to 600 will still be worthwhile and fun.
Hell, my stock 2JZ-GE is fun, and I think its fast as sh-- honestly, compared to the asthmatic 4cyl. I used to drive.
I just want more of that exhilarating feeling, 'cus I like getting sucked into the back o' my seat, like "HOLY SH--!!!"
Cool.. 1JZ it is, then.
Thanks!
Thanks!
We do quite a few both TT's and NA-T's. I would strongly suggest going with an NA-T unless you really don't like the way the distributor "looks". You'll get better performance, and have a lot more updated motor without having to mess with the wiring harness ordeal.
Plus, in a street sc, you want all the displacement you can get if you want to keep up with other punchy cars.
Ian
Ian
Lol another 1j vs 2j thread....ive owner both 1j and 2j engines and the reason i kept my 1j because of the gas milage and the smooth rev happy powerband. You can build a 1j to put out more power than a 2j .it all depends on how deep your pockets are. either way you look at it they are both great motors for 450-700 hp on the stock block. its all depends on what you want to do. If you want to go na-t get a good block and a good ems and you should be good. Me personally would not boost a engine with that milage
You'll be going backwards with the 1jz swap. Less displacement for starters. Then, if you want more power(and You Will), you will end up doing what you should have from the start....switching over to a single turbo setup. Which means a new turbo/manifold and other supporting mods.
You should consider going NA-t, you'll have the option to build the way you want from the start, and your not stuck with the distributor if thats what your worried about. There are a few options as to replacing the distributor and going coil on plug ignition.
You haven't parket next to the right NA-t You can build your NA-t to look great too.
In the end it comes down to your budget and long term goals.
- gets more Ahhhs and Oooohs than NA-T
Ian
Ian
and im happy with that...
Because I don't plan to race 800hp street machines. I would be happy with between 350 and 400bhp. Plus I am a college student and though a 2jz would be nice through research people keep saying they end up spending thousands of dollars to get their motor running. Thanks Toyota for all the choices
you need a 2jz-gte to do the 1.5JZ, the 2jz-ge won't work with the 1jz head or everyone would do that since the intake manifold is the main problem with the N/A motor.
At that point you are better off doing a 2j GTE. You've got to swap the wiring harnesses either way, and the 2j head flows better than the 1j head, I don't care what anyone says. The 1.5jz was a "budget" combo, it isn't preferred due to better head flow of the 1jz like some suggest. It is an effective way to dump the dist. for coil packs and get a factory twin setup. Its a great motor, no question, but so is an NA-T when set up properly.
If you consider the costs of doing it right; tearing into the motor and getting a gasket kit, oil pump, water pump, new timing belt and tensioner, it ads up very quickly.
Ian
I have a 1jzgte and i think i will end up building the 2jzge taht i have, slowly. meanwhile drive the **** out of this 1jzgte. I had to replace a lot of crap on this 1jzgte r154 engine kit i bought. So far its been turbos(single turbo now), radiator, ps pump, alternator, coil clips, etc i cant think of anymore. I am planning on swaping a lot of stuff over tho like the EMS, Hopfuly most of the fuel setup, turbo(buy larger housings for 2jzge) and obviously the FMIC(prolly build a intake to mate them up). The list goes on if your conscience of what your buying(in the fact taht you might be able to use it on both motors)
