oooooo....oooo..oooo subscribed. I would like to see if anyone had the info. Pictures are good but I would love to be able to walk into my machine shop and give them dimensions on all the sub frame mounts and diff mounts to make me some. I know we have talked about it before 5sp. Maybe once I get the engine swap done (Fn HARNESS!!!) I will put some effort into that. I would also like to do the rear subframe mount with the TT sway bar add on so I can mount me sway bar.
i just did a whole subframe/bushing swap on mine. what do you wanna know.
btw Biggu if your alignment bolts in the rear are seized and you need new ones i have the part numbers.
do you have part numbers for the front LCA alignment bolts, mine are sized to the bushings.
i want a picture of the underside of the car with the diff out or if someone could tell me what the black hose is running above it (cv grease?), about 12mm thick?
