1jz tensioner Question, Help
Old Jan 23, 2009 | 08:26 PM
96sc's Avatar
96sc
Default 1jz tensioner Question, Help
So i am installing a 1jz vvti in my lexus sc, i have a problem, i lost the timing belt tensioner, and the crank pulley. I took them off to do the timing belt and to paint them, now that i got my harness back, I cant find where i put them.
Anyway I tried to put my 2j ge tensioner and crank pulley on but they are different and do not work together at all. I am pretty sure its just the tensioner that is different, can anyone confirm this for me. Pretty sure the crank pulleys are all the same.
I found a tensioner for sale from an older model 1jz 87-82, are these the same on all 1jz engines? Are they stamped 2.5, the ge is stamped 3.0.
thanks in advance.
Old Jan 23, 2009 | 09:21 PM
RyanV's Avatar
RyanV
You should also post this on Supraforums under the MKIII 1J swap section.
Old Jan 28, 2009 | 07:45 AM
96sc's Avatar
96sc
Default tensioner
World exclusive thanks to Larry and Chris at Sound Performance. This information was not on clubna-t, supraforums or here.
They allowed me to bring in a stock 2jz ge and 2jz gte tensioner which are identical to compare to a 1jz they had there on this issue.
The 1jz is a little shorter then both of them, to answer my own question.
Hope this will help others.
Old Jan 28, 2009 | 10:14 AM
RyanV's Avatar
RyanV
Interesting find!
Considering the different timing belt, doesn't surprise me. what about the tensioner pulley?
I've been told that they interchange.
Old Jan 28, 2009 | 10:16 AM
shern's Avatar
shern
Thanks for the info. Someday I'd like to *** with a 1JZ VVTi.
Old Jan 28, 2009 | 10:33 AM
96sc's Avatar
96sc
Default tensioner
This tensioner is for the accessories, not related to the timing belt at all, but if you dont lose it, u should be good. , i will post photos up of the car as i get it going, no rush its way to cold here to think about it.
Old Jan 28, 2009 | 10:35 AM
96sc's Avatar
96sc
Default pulley
The pulley is different in some cases and in others the same, i still have my original pulley which is plastic and mounts differently. The used one i bought from an older 1jz has the same metal pulley as the na 3.0, they appear to be the same exact size.
SEIDO
SC400 / 300 Classifieds
Sep 23, 2009 09:50 PM
mo_jo
Mar 27, 2007 06:02 PM
sc300gte
Mar 24, 2007 10:51 AM
happypanda
Apr 30, 2006 10:56 AM
aswang
Aug 2, 2005 02:56 PM
