Car runs rough and stalls at idle after spark plug,wires,cap, and rotor change
Hello, I just replaced the Spark plugs, wires, caps, and rotors on my SC400. The car hesitates during slow acceleration but runs find under full acceleration. At stoplights, the car stalls and idles a little rough, I just build a custom intake with a tube going from the maf to a kn filter in the bumper if that helps. one of the new wires got frayed a little on the belt on accident, but just through the black rubber, Could that be the problem, or could it be something else? thanks alot
did you try to reset your ecu?
disconnect your battery for about 10 min then reconnect it, that will reset your ecu. try it. |
maybe you took too big of a hit before working on the lex? lol :p jk
uh things that come to mind, well rotor on backward, well not likely as it would not run uh.. cracked sparkplug, not likely.... uh maf unplugged... is the check engine light on? you said you nicked a plug wire. if it is cut enough and is arcing onto some part of the engine that would cause a rough running condition. any air leaks in the intake system causing unmetered air enter after the maf? too much k&n oil on the filter causing the maf to read incorrectly? there you go. you should be thankful its friday and i"m still @ home, not for long though :):) good luck |
thanks guys, i took a look at the vacuum system, and one of the tubes is leaking. im gonna replace it tomorrow and hopefully everything will be ok.
Originally Posted by DRFT103
(Post 4025572)
disconnect your battery for about 10 min then reconnect it, that will reset your ecu. try it. But yes, get that vac line fixed and your should be fine. its amazing what one or two leaking lines will do to your idle and overall behavior of the car. |
if it doesn't go away, you might want to check the plug wires, the cam gears/timing belt likes to eat them
