My 94 build up!! NA-T
Old Nov 19, 2008 | 10:01 PM
1sxyrxy's Avatar
1sxyrxy
rear main could get blown out due to bad/worn piston rings, make sure you crank case ventlation is working correctly. do compression test
Old Nov 20, 2008 | 04:15 AM
trbo1stgen's Avatar
trbo1stgen
how would i go about checking crankcase ventlation....wow i hope its not anything bottom end related.
Old Nov 20, 2008 | 07:48 AM
gabegtz84's Avatar
gabegtz84
Nice pipes and those rims are pretty gnarly my buddy used to have those on his S2k they get the ladies attention.
Old Nov 20, 2008 | 04:41 PM
trbo1stgen's Avatar
trbo1stgen
anybody on crankcase pressure? how would i go about checking oil pressure?
Old Dec 2, 2008 | 10:27 AM
trbo1stgen's Avatar
trbo1stgen
clutch is finally in, fixing the drain line today. And then a tune!
Old Dec 4, 2008 | 03:52 PM
sc5spd's Avatar
sc5spd
setup is looking good.
Old Dec 4, 2008 | 09:27 PM
stevechumo's Avatar
stevechumo
The symptoms that you have about the leaking oil and the clutch aren't really related to the turbo system. The angle of the turbo oil line has nothing with the leaking oil and slipping clutch. When you boost, the clutch might go bad because of the additional pressure and torque that put on it. With boost, you increase more hp and torque so any nearly aging parts and seals will show their weakness. You'll need new parts, perhaps more than just the clutch and the rear main seal. Maybe more seals and gaskets will start to give out, including the vacuum lines...etc. The point is the engine needs to be prepared with good condition parts when under boost.
You'll need an air breather to vent the excessive blow-by oil pressure, or you can use an oil catch can. You can search on Ebay.
The stock setup usually has 1 hose connecting from the valve cover to the intake pipe right before the throttle body. This excessive oil will be consumed in the combustion. Now you eliminate that for the turbo intake pipe, so you'll need a place to vent that pressure to.
Old Dec 5, 2008 | 03:57 PM
trbo1stgen's Avatar
trbo1stgen
drove the car with the clutch and coupler yesterday, pulled hard. just did one pull cause i have to break the clutch in.
took apart everything on the drain,and everthing down there was hand loose, so we tightened everything up, and fixed the gaskets. and now no smoke, or leaks( first time ever)
Old Dec 6, 2008 | 10:27 AM
2jzlex's Avatar
2jzlex
trbo1stgen do you mean you tried to make pulls with a bad coupling, or you just got it together for the first time with the new coupling?
Old Dec 7, 2008 | 11:18 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
how is the map ecu working out for you. Does your car run find with the stock base map?
2jzforlife
May 1, 2015 07:40 AM
Gensc300
GS - 1st Gen (1993-1997)
Jun 14, 2013 07:42 PM
ZSC3
Mar 25, 2009 05:35 PM
SlideMySC
Oct 11, 2004 09:49 AM
