What's the one electronic device to use that..........
Old Jun 4, 2008 | 03:44 PM
HellFish's Avatar
HellFish
Default What's the one electronic device to use that..........
im curious as to why you want to lean out your air fuel ratio
Old Jun 4, 2008 | 03:48 PM
JspecSC3's Avatar
JspecSC3
There are quite a few options available to you that can do that. If you would like more information about parts available for you motor feel free to post in the Engine/Performance section. You'll get alot more responses there.
Old Jun 4, 2008 | 04:19 PM
HELLAFLUSH's Avatar
HELLAFLUSH
1) To fix a rich condition.
2) To think you can save gas but really, are damaging the engine. LOL.
Old Jun 4, 2008 | 05:10 PM
Dx3's Avatar
Dx3
The device is called a wideband.
The reason you would lean out your air/fuel is so your car will run more efficiently. More efficient = better gas mileage, faster, doesn't foul your plugs, etc.
But it is better to be too rich than too lean...
Jonny
Old Jun 4, 2008 | 06:17 PM
madmax98's Avatar
madmax98
I wanted to lean out my AFR for fuel consumption reasons like DX3 said. I also forgot to say that i have a Blue E-Manage on hand, so is it possible to use that for the reasons intended or should i just sell it and get the SAFC-II.
Old Jun 5, 2008 | 04:11 PM
Spooled's Avatar
Spooled
all a wideband does is tell you real-time AFR. has nothing to do with adjusting it. You'll need a Apexi SAFC1 or SAFC2, unless you have AEM EMS or E-Manage, like you said you do have, so in the end the E-Manage should be all you need.
But in all reality, it sounds like you need to take it to a professional tuner, and dont risk it. A couple fat-fingered clicks here and there can destroy your engine. If you think you're running too rich there might be something wrong with the car, not just needing to be "leaned out".
Old Jun 5, 2008 | 05:37 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
teh ladies love it when it is lean?
Old Jun 5, 2008 | 05:58 PM
madmax98's Avatar
madmax98
My car isn't awefully rich, but 14 MPG is beyond my tolerance and i'd like to lean it out a little. I do have the Emanage blue ,but which is easier to tune with Emanage or SAFCII?? Also i don't plan on leaning without and EGT and WB..
Old Jun 6, 2008 | 07:28 AM
Spooled's Avatar
Spooled
I'd look at a few different area's before trying to lean the car out.
For instance, does your car have aftermarket wheels? Any performance upgrades? Do you drive with a heavy foot? when was the last time you did a tune-up, plugs & wires-(if it has a dist.), fuel filter, air filter, etc. If stock, have you tried a different air filter? what kind of fuel are you using?
Nature of the beast. But attacking fuel directly might not be the way to go about this.
Old Jun 6, 2008 | 04:55 PM
Spooled's Avatar
Spooled
Nevermind all previous statements, here's your solution:
Old Jun 6, 2008 | 05:13 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
RX3302004
Sep 11, 2013 09:59 PM
SMigone
Performance
Sep 8, 2011 04:59 AM
dahozy
Maintenance
Apr 24, 2009 01:22 PM
1995LS400
20
Apr 9, 2008 08:54 PM
