Pre 95 and 95+/Supra W58
I was just wondering is the 95+/Supra W58 a direct swap for the pre 95 w58. Thanks.
Also, are the pre 95 w58's the same as MKIII w58's? |
Originally Posted by DryBlaze
(Post 3418317)
Also, are the pre 95 w58's the same as MKIII w58's? On the other hand, the MK3 W58 is different from the pre-95 W58 in that the shifter position is in a slightly more forward location. You would have the same issue trying to swap a MK3 W58 that you would trying to swap a MK3 R154 into an SC. The pre-95 W58 is a closer relative to the MK3 W58 in that both utilize a swan-neck shifter; however, the length of the shifter housing and shift linkage is longer in the SC transmission. |
Blizzy, have you ever looked into using the shifter extension and control lever off a mk3 w58 or pre 95 sc w58 for the mk3 r154? It looks very similar to the one you got from the soarer r154?
