Problem 1JZGTE At high rpms, getting cut/limiter
Old Dec 20, 2007 | 07:55 AM
thegadget's Avatar
thegadget
Unhappy Problem 1JZGTE At high rpms, getting cut/limiter
When I am in performance mode on the auto(and wot), I am either getting the rev limiter (shouldn't be hitting it, not even close to the red line) or I am getting a boost cut?!?
Not sure what it is, but it is really irritating. Can you guys give me any ideas why it would do this? I would really appreciate it. It is the same thing I am getting when I am hitting the 100-120mph as well. Feels like fuel cut, maybe. Anyway any ideas will help. I am not manually shifting the auto, I am using the performance mode(shouldn't it know when to shift?).
Thanks!!
Old Dec 20, 2007 | 08:29 AM
audi2nr's Avatar
audi2nr
do u have a fmic? how much boost are you running? use to hit fuel cut all the time with no exhaust due to the lack of restriction by an exhaust system, i have one now and i only hit fuel cut occasionally only when its really cold outside and the ic is working extremely well.
Old Dec 20, 2007 | 07:58 PM
nate579's Avatar
nate579
Now I know how it feels when you hit the redline and fuel cut out but, what do you feel when it's boost cut? Does it shudder, like something holding you back? Mine does that on occassion when I am passing around 4k rpm then it back in boost.
Old Dec 21, 2007 | 08:27 AM
thegadget's Avatar
thegadget
Talking
Well, got home yesterday, and MY SC300 GUAGE cluster came in!!!!! YAY! At least I will know when I am hitting the limiter.
I still need to get a fuel/air & boost gauge. Haven't got an electric boost controller either. I am working on getting most of this setup, just having a hard time with the engine side of it.
Old Dec 21, 2007 | 05:27 PM
audi2nr's Avatar
audi2nr
i'm prettysure fuel cut/boost cut is the same, the reason people call it boost cut is because once the map sensor reads too much pressure the fuel injectors are turned off till the pressure drops to the factory level. the feeling you get is complete powerloss, kinda like someone pulling the e-brake.
Old Dec 23, 2007 | 10:49 PM
thegadget's Avatar
thegadget
I will try to post a vid of what I am experiencing.
Old Dec 24, 2007 | 09:38 AM
sc250tt's Avatar
sc250tt
Its probably fuel cut.....You should invest in a boost guage and a fcd.
Old Dec 24, 2007 | 10:45 AM
thegadget's Avatar
thegadget
So FCD=Fuel Cut Defencer? Ok, so what guages should I get? I was looking for a boost gauge, then I found a BCU+ Electronic Boost Controller. Will this work for a gauge too? Or should I have both?
Ok, now how would I monitor the air/fuel mix? Would I need a wideband guage?
Well, What gauges do you recommend, and how many? Where can I find a pillar mount?
Oh, did you get a SC300 cluster for your SC4? sc250tt?
Old Dec 26, 2007 | 12:05 PM
sc250tt's Avatar
sc250tt
At least a boost guage and a narrowband. Most boost controllers are more accurate than a guage so if you get one youre good to go. They don't have any pillar mounts for our cars so youwill have to retrofit or make your own . As for the cluster no i did not get a sc3 cluster , not really looking for one .The is alot more onfo on this topic on clublexus so dont be afraid to use the search feature on here.
Old Dec 26, 2007 | 03:11 PM
shonuff53's Avatar
shonuff53
I have to agree with everyone on else on that boost cut issue, up here in pa I just got my swap up (1j) and Im experiencing the same problem with and intercooler and downpipe, troubleshot it and it would only occur and full load next I hooked up a boost meter and as I hit 4k slightly passing 12lbs fuel cut kicked me in my back. now I just bought a hks fcd and am wondering what setting I put it on and which wire on the ecu is my press sensor wire?
GTE4Life
May 24, 2013 01:24 PM
stockhatch
Oct 20, 2010 06:21 AM
96sc300
Nov 26, 2008 03:21 PM
blaznsc4
Jun 3, 2007 08:18 PM
GRSC400
Feb 23, 2006 09:27 PM
