exhaust cams and porting for power
Old 01-20-02, 04:19 AM
UZZ32
UZZ32's Avatar
Default exhaust cams and porting for power
I am reading a book called "21st Century Performance" by Julian Edgar at the moment.
You can buy it from the www.autospeed.com site in the shop.
Anyway there are two particular chapters with very interesting information on the 1UZ-FE V8.
The first chapter "Engine and Driveline" part "camshafts" has a whole section about the 1UZ-FE camshafts and how they compare to other high performance engines. Standard specs are listed and they model changes (using Dyno2000 software) to the cams and resulting horspower increases.
The most effective would seem to be changing the standard exhaust cam for an exhaust cam with revised opening of 55 degrees BBDC (Before Bottom Dead Centre) and closing of 18 ATDC (After Top Dead Centre) (standard exhaust is 46 BBDC and 3 ATDC). This changed exhaust cam with the standard intake increased the horsepower from 260 to 300 !! (modelled on Dyno2000).
Although changing the exhaust cam (getting it welded and reground?) doesn't sound like a simple job.
The second very interesting bit is head porting. A 1UZ-FE head is flowbenched before and afterward being ported. Increases in flow on the bench usually relate directly to horsepower increases. After porting the intake flow increased by 19 percent and the exhaust by 14 percent!!! These are actual flow bench figures. Not only that but there are 12 full colour photos of before and after closeups of all the critical parts to pay attention to when porting. An extimated 20 hours was spent porting both heads.
I haven't heard of anyone ever trying different cams (only a supercharged 1UZ-FE, Ivan Tighe did those) or porting the heads for a street car -
Anyone heard anything or given it a go?
Old 01-20-02, 03:08 PM
matt7184
matt7184's Avatar
"The most effective would seem to be changing the standard exhaust cam for an exhaust cam with revised opening of 55 degrees BBDC (Before Bottom Dead Centre) and closing of 18 ATDC (After Top Dead Centre) (standard exhaust is 46 BBDC and 3 ATDC). This changed exhaust cam with the standard intake increased the horsepower from 260 to 300 !! (modelled on Dyno2000). "
Doesnt surprise me at all. I believe the VVT-i 1UZ-FE's had their cam shaft timing, etc revised and they are at about the same pwr lvls.
"Although changing the exhaust cam (getting it welded and reground?) doesn't sound like a simple job. "
If we can get camshaft blanks then it should be easier to find a shop willing to grind them.
"The second very interesting bit is head porting. A 1UZ-FE head is flowbenched before and afterward being ported. Increases in flow on the bench usually relate directly to horsepower increases. After porting the intake flow increased by 19 percent and the exhaust by 14 percent!!! These are actual flow bench figures. Not only that but there are 12 full colour photos of before and after closeups of all the critical parts to pay attention to when porting. An extimated 20 hours was spent porting both heads. "
Seems like we would see huge gains in performance like the LS1 guys from heads and cams.
Old 03-15-02, 08:06 AM
UZZ32
UZZ32's Avatar
My exhaust cams were finished today ! -Should get them back early next week, then another week to see if it was worth it. Read the story so far on my site
Old 03-15-02, 09:16 AM
Lex Luthor
Lex Luthor's Avatar
Peter, didn't know you were having it done, looking forward to hearing the results from you. Ivan Tighe did the cams on the Powerhouse Soarer, right? Are you familiar at all with this gentleman Greg Gower that did the headwork for them? If the dyno software and flowbench are right, there's lots of potential here, which we all suspected, we just need guys like you to go ahead and start the trial and error, let us know as soon as it's all buttoned up, and have Natasha take some video of you burning the belts off your tyres.
Cheers -
Jon
Old 03-15-02, 09:37 AM
Bean
Bean's Avatar
oh sweet! let us know how it goes...
Old 04-06-02, 05:59 PM
UZZ32
UZZ32's Avatar
Modified V8 exhaust cams are back and in the car. But there has been a small hiccup....... (see website)
Old 04-06-02, 09:05 PM
Lex Luthor
Lex Luthor's Avatar
Peter, less us know when the shims are done. By the way, lost that pic of your adjustable rear headrests, mind posting it again? Thanks from your Yankee ******,
- Jon
Old 04-07-02, 06:17 AM
UZZ32
UZZ32's Avatar
Check out the new headrest page!
Old 04-07-02, 11:02 AM
Lex Luthor
Lex Luthor's Avatar
Everyone's a comedian
Old 05-29-08, 08:11 PM
RX400
RX400's Avatar
Wink Goreisms
You will be cursed for speaking the truth. But I praise your courage!
Old 05-29-08, 08:24 PM
Dx3
Dx3's Avatar
Holy 6 year old thread bump
Jonny
Old 10-09-08, 10:37 AM
VEGAS DRE
VEGAS DRE's Avatar
i was hoping that there wouldve been more info/responses on this subject in the past 6 years !
sdqqbb
03-11-17 03:34 PM
UZZ32
Performance
07-15-07 04:29 PM
2JZGE
Performance
03-27-02 01:46 PM
Quick Reply: exhaust cams and porting for power
