(domestic) V8 in a SC300/400
dont' flame me for asking this:
but anyone ever put in a domestic V8 in a sc300/400? any of the small block or big block v8's.
i was planning to do a project SC drag car with the built 2jz. but have sort of changed my mind/direction and was experimenting with the thought of going domestic v8 (more power and on less octane) in a NICE car (such as the lexus SC300/400) so it'll have the best of both worlds.
i had a 750hp supra before and know that power can be made by the 2jz but i wanted to run a BIG turbo and wanted to shoot for some big power 1000-1200whp. i believe building a built v8 motor would be cheaper than the 2jz's. plus i wouldn't need nitrous to spool it off the line!
i know the main concern for me would be the oil pan mounting up properly, clearance of the cross members and steering rack.
if anyone has done it though please post pics or info about it!
thanks!
thanks!
honestly, if you knew a good fab shop, I am sure they could build you a custom cross member that would allow an LS1, LT1, etc to fit inside. The engine bay is a limiting factor. But, if you threw out all the luxuries like A/C and P/S and went simple and easy for a straight drag set-up, I bet you could a nice-sized V8.
that being said, I would check with Eric (Cowboy) and TTC Performance. He can build you a stroked 2UZ from a Tundra with forged everything and a stroked crank to 5.5L. Put two snails on that thing, and you are talking 1000+wtq on a Toyota motor that would mount right in.
It might be easier and less hassle in the long run to just run a stroked 2UZ. Eric even designed an intake manifold that is really pretty damn sweet. A 5.5L TT quad cam Toyota motor in an SC: sweet jesus.
Iron block, and twin turbo
Eric
you know of a thing called a boost controller right? it was turned all the way down (17psi), it was probably ~550-600whp or so on those runs. yes i should have gotten in the 10's witha better 60' foot.
never got to run it at 750whp (25psi). what have YOU ran anyway if you ever did?
traction= no problem, didn't spin at all but didn't have a good 60' 1.7's
power= wanted to run at full tilt 30psi (800~whp) but decided to start at the base boost (17psi) to get used to the car first.
so there you have it of my former supra and my one night of drag racing. can we please get back onto topic? thank you
i understand this isn't the most conventional way and i might get flamed a lot for bringing this topic up. just wanted to see my different options to look at. i think having a built v8tt in a lexus body would be pretty spectacular imo
how bout a supercharged 2UZ drag car? found this on lextreme....
http://www.aeromanagement.com.au/racing/outlaw.html
this thing is bad ***!!!
Its been done before. I do recall somewhere out on the interweb, I came across a picture of a SC with a LT1 swap. Haven't been able to find the picture again though.
find a fab shop. I am sure they could make you a custom cross-member to get the engine in the vehicle. Use an LS1 tranny, get a custom driveshaft, and go nuts.
