found a motor
found a motor
this motor comes with the jdm head,manifold,turbos,ecu,distributor and alternator..what else is need from a TT to get the motor running..itsa 2jzgtte by the way
You will need the Ignition Ignitor and EFI resistor unit, Ignition Noise suppressor, power steering pump w/ remote reservoir, Supra fan shround if available, Brake Booster one-way vacuum valve, Fuel pump (Lexus stock won't cut it), complete uncut wiring harness, downpipe/cat (you will need the flange to mate to your Lexus or aftermarket exhaust system).
Finally, of course, hopefully you can get the intercooler and all associated piping.
GTE_SC3
Performance & Maintenance
07-20-07 03:56 PM
