dual walbro setup
I have done a few twin setups in SC's and have it down to science. Typically i run 2 -6 bulkheads on the tank, and y them off to a single -8 all the way to the rail. I mod the stock rail and use the stock feed as the return. Ill hit you up with some pics of this one we are doing at the shop right now. The wiring is simple, dual relay setup with a fusable link works well and is straight forward.
not only that, but intank pumps are quieter, stay cooler becuase they are submerged in fuel, and they also dont require running a fuel cell.
If you have a very large TURBO, 1 pump will not provide enough fuel. It's the increase in delivered air to the motor that requires more fuel not a bigger injector.
I've seen people out run one walbro fuel pump anywhere from 590whp (lexluther) to 690whp (me). So, it can happen. In my case, the second pump was programmed to come on at 14psi, but rescaling my fuel map from 3-bar MAP to 5-bar MAP goofed up the load breakpoint for the second pump activation. Fortunately, I caught it on the dyno before it caused a problem. You can read about it here: http://www.supraforums.com/forum/sho...d.php?t=380446
-scott
-scott
DoomLight
Performance & Maintenance
29
04-27-17 10:13 AM
