About to do a auto to 5 speed swap
Old Feb 8, 2006 | 01:03 AM
stormeye's Avatar
stormeye
Default Need help : about to do a auto to 5 speed swap
Hi. I'm planning on doing an auto to 5 speed (w58) swap in my 97 sc300 pretty soon.
So far I have gathered most of the parts I need for the swap.
The only aftermarket stuffs I need would be a clutch disc, pressure plate and flywheel.
Some people were saying I should just use the oem flywheel out of the 5 speed sc.
I've already done quite some search through the CL threads so far but I'm a bit confused on which brand to choose. RPS, ACT, HPF, CM are some of the brands I considered as far as being reliable.
I also do have plans on adding a turbo kit later on, but not right now. SC would be my daily driving car. A lot of city driving since I live in L.A.
Any help?
Old Feb 8, 2006 | 02:25 PM
JspecSC3's Avatar
JspecSC3
About how long do you think it will take for you until you get that turbo kit in? If its more than 6 months I would suggest sticking with an OEM clutch kit for now. When I swapped out my transmission to a W58 5speed I just stuck with the OEM stuff because I dont think I wont be boosting until maybe after summer. About the flywheel, I'd just stick with the stock 5speed one unless you are planning on putting out moderate to high amounts of horsepower. Then I would get like a Fidanza or something.
Old Feb 8, 2006 | 03:27 PM
SUPRMSC's Avatar
SUPRMSC
What Jspec said, keep the stock 5 spd clutch until you have the power. Might as well use it while it's there instead of wasting your aftermarket clutch.
Old Feb 8, 2006 | 03:55 PM
ConSynX's Avatar
ConSynX
to save ya hassle later on you want 75w90 gear oil
sadly, i dunno the FULL capacity of the tranny.
Old Feb 9, 2006 | 07:30 PM
stormeye's Avatar
stormeye
Default How about a short throw shifter?
ten four. thanks for your input guys.
i will just use then the stock sc 5 speed flywheel, clutch disk and so on.
btw, how about a short throw shifter like B&M or C's? any preference?
MongooseGA
SC400 / 300 Classifieds
22
Apr 24, 2012 05:32 PM
JDMSoarer5
Jan 18, 2011 12:31 PM
bzebern
Jun 23, 2008 06:35 PM
SCDrift
May 18, 2008 03:35 PM
