VIDEO..what's this cricket noise?
Old 10-29-05, 07:21 PM
Todd1225
Todd1225's Avatar
Default VIDEO..what's this cricket noise?
Started noticing this "cricket" sounding noise a couple of days ago...checked all the fluids and only the power steering fluid was a little low, but that would make a whining noise anyway. Serpentine belt was replaced about 2 months ago. Other than this noise, car is rock solid with no other issues.
The noise gets faster with the engine, but doens't match the rpm's. A/C on or off doesn't affect the noise, neither does the clutch being in or out.
Right Click Save AS ( 1 MB ) Video with Sound
Old 10-29-05, 08:10 PM
IronCobra
IronCobra's Avatar
Your timing belt or drive belt tensioner.. I'm 100% sure of this.
Link to buy one
I think they are working on the site though.
Old 10-29-05, 08:26 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
THAT is a bearing. I'm 100% sure of this
For real, alternator or water pump is most likely. That's similar to a belt sound, but the high pitch makes me think more metallic, which is a bearing.
Old 10-29-05, 08:37 PM
IronCobra
IronCobra's Avatar
hhmm maybe.. my 95 SC400 I had made that EXACT same sound when my tensioner started to get old.. it was the bearings in the tensioner
Old 10-29-05, 08:38 PM
Todd1225
Todd1225's Avatar
Sprayed the serpentine belt with a little belt conditioner and the noise got worse..then gradually got back to normal. When they replaced my A/C compressor they put the old serp belt back on, and it squeaked like crazy, spraying it with belt dressing made it do away for about 2-3 mins...swapped on a new belt from NAPA and life was good.
I would say the conditioner helped a little once it quieted back down. Crap...no road trip for me....
Old 10-29-05, 08:39 PM
IronCobra
IronCobra's Avatar
Shouldn't be anything that will effect the car that much. I drove with mine making that noise for MONTHS before I got it fixed. Even the shops said its not that big of a deal...
I'm sure you need to get it fixed, but you probably don't have to rush into this one.
Old 10-30-05, 10:24 AM
iasc300
iasc300's Avatar
sounds like a bearing but not completely sure- good luck bro
Old 10-30-05, 12:57 PM
ki_soarer
ki_soarer's Avatar
i would have to say its a tensioner. i see a lot of this on the BMWs at work, and the sound is very simmilar.
Old 10-31-05, 03:29 PM
Todd1225
Todd1225's Avatar
It was the belt. Apparently the belt conditioner left over from the other belt was still on the pulleys. It was causing a problem or I just had a bad belt. Pulled the belt off, washed down the all the pulleys with carb cleaner and wiped them off good...put on a new belt and it's quiet as a mouse. My mechanic said the tensioner was fine and the marks on top were in the right spot.
HE ALSO WARNED TO NEVER, EVER SPRAY BELT CONDITIONER ON A RIBBED BELT.
Old 10-31-05, 10:08 PM
NuttySC
NuttySC's Avatar
go to your autotech persone (who ever that my be) and get it checked
Old 10-31-05, 10:16 PM
indelible
indelible's Avatar
He already got it checked...
DocT
LX - 3rd Gen (2008-2021)
23
06-19-16 03:44 AM
Knarf916
12-06-15 10:21 PM
pinoiryder
02-07-11 09:50 AM
EnzoRX
RX - 1st Gen (1999-2003)
12-27-02 04:31 AM
Quick Reply: VIDEO..what's this cricket noise?
