Help AUTO. stalling out and dieing!!!
well here's the info. when i make hard right turns and excellerate out of them at all, my car stalls out and dies, i drive a 92 sc300 auto., it's been doing this for about a month now, and then today i was sitting at a stop light and the car just died, (first time it's done this) but it did it twice today!!!!! wth is going on with my car, i replaced all the fluids with full syn. and it's still doing it. I was kinda hoping some1 would have a clue
Hmmmm, just taking a guess. I'm not a full mechanic just yet and I hate working on transmissions, but it might be two of one things. Either A) you're torque converter has taken a dump on you, or B) you're trans is fried. Is it slipping out of gear at all? Is it reving high then lurching?
Quite possibly the fuel pump ECU is starting to die, it's a glorified relay used to switch the fuel pump from hi/lo modes.
Try the diagnostic jumper detailed on my site, if this resolves the cutting out you will need to replace the fuel ECU.
SoarerTT
SoarerTT
Mortgage Slave
My Soarer (for about a month now) has stayed in first gear until around 30~35km/h then drops properly into second then third (sometimes it doesn't even stay in second gear)... and when I shift from Park to Drive there's lag in the gearbox... any ideas?
Jose
The Gearbox issues should really be another thread, but seeing as we are here;
What fluid are you using in the autobox and is it full? We only use Toyota Type4 fluid, it can make a hell of a difference to the way the box works.
If you have sh1tty old trans fluid get it flushed and replaced with Type4, drop and clean or replace the filter, (Toyota Type4 is bloody cheap in Oz and Really Bloody Expensive in England £40/4Ltrs and you need 12Ltrs do do a full flush) This might just be enough to revive you autobox, if it dont work the box is probably sh4gged.
Dont consider a box rebuild, difficult to get right (very few people have had experience in re-building the Toyota A340 gearbox because they rarely go wrong) and highly labour intensive, get a warranted s/hand box from a breaker, theres plenty around.
Mortgage Slave
Hi Bill,
Cheers for that I've got Toyota T-IV running through my gearbox's veins. It was flushed and refilled when I had the 150K service done, I've now got 187K and it's only happened recently.
Neil's got an auto box with shift kit going for AUD$1000, but I dunno if I should keep on saving for an R154 conversion.
The symptoms are just like the failure I had with my TT autobox, then I lost 1st & reverse (same clutch I was informed). I had a "rebuild" done by a transmission specialist, it went back four times in a year with various faults. Eventually I bought a cheap s/hand box which is still running fine now after 40,000mls.
I have driven a manual TT and it really ruins the Soarer smoothness, it's hard work to keep it from doing neck snapping gear changes. I am a lazy sod anyway, I gave up manuals a long time ago.
I would buy that box today if it wernt in Australia
well, both were real simple fixes, the car cutting out stalling and dieing, was a bad fuel filter, it was choking the engine out, and the right hand turns ended up being the battery tie down, i found the back tie rod was off lol, so i tightened them back down secure as ****, and now the car runs perfect,
my car is still really hesitating on shifts though, so im going to just starting saving for a w58 conversion any1 know any1 selling any conversion parts???
tenac2215
Performance & Maintenance
03-23-17 11:20 AM
