r154 tranny
Old Feb 22, 2004 | 04:59 PM
l7in6k's Avatar
l7in6k
Default r154 tranny
In japan the 1jz comes w/ the r154 tranny which is much stronger rt? I have blown through two trannies in two wks. w/ my 2jz but don't want to go w/ the getrag. Would the r154 fit in the sc with no major modifications. I've heard that the r154 will have a different shifter location and also that it will not. Someone help asap! Thanks
Old Feb 23, 2004 | 07:38 AM
kaotiq's Avatar
kaotiq
The R154 is a good tranny for boost and yes it did come with the 1j.
in order to get it to fit, you have to get a 2j bell housing i believe.... not 100% sure but i know the bell housing from the r154 to the 2j wont fit.
if you goto the supra boards. do a search and you will find a lot more info there.
Old Feb 24, 2004 | 08:07 PM
MrJohnTan's Avatar
MrJohnTan
sup tommy. steve told me about the car.... good stuff man! lol, thats when you know youre making power. anyways, do search for a user named "Bean" I know he has done the R154 swap into his car. goodluck.
EDIT: this might help a little. https://www.clublexus.com/forums/sho...ight=bean+r154
Old Feb 24, 2004 | 10:24 PM
Bean's Avatar
Bean
CL Folding 1,000,000
I havent done the r154 swap i would really like to eventually though
for the record i believe it requires a 1jz bellhousing, a 1jz or 2jz-gte flywheel, a 7M clutch disc, and a 2jz pressure plate...
someone correct me if i'm wrong; i'm pretty sure there's more info at supraforums
Old Feb 25, 2004 | 03:58 PM
MrJohnTan's Avatar
MrJohnTan
oops, i read your sig wrong
KaliSoarer
SC400 / 300 Classifieds
May 27, 2010 06:55 AM
nemo6686
Nov 25, 2006 04:26 PM
soardrft
Sep 13, 2005 05:53 PM
got_trd
Mar 18, 2004 03:50 AM
