AEM v2 No Spark
Old Sep 6, 2024 | 07:52 AM
udfxrookie's Avatar
udfxrookie
Unhappy AEM v2 No Spark
So my problems started when I had the insane 32 tooth timing crank gear and found out it won't work with aem v2
I got the new 12 tooth timing gear for the crank and put that on....
In wizard I had selected the "Toyota/Lexus 2JZ-GE distributor" uploaded it and during cranking I don't see the
Crank Tooth Period moving at all (T2PER does though)
Go back to wizard and select the "Toyota Supra 2JZ-GTE" uploaded it and during cranking the Crank Tooth
Period DOES move... I saw 'Stat Sync'd' go On 1 time.... never again LMAO
I have a 1997 Lexus SC300 with a 2JZ-GE non VVTi with the distributor and now the 12 tooth timing crank sprocket.
I have no spark.... I did also notice the 02 looks like it may be reading wrong, not sure if that matters to get the
engine started?
I uploaded screenshots of the Sensors tab and the Adv Pickups tab... maybe I have something setup wrong?
Old Sep 6, 2024 | 11:34 AM
udfxrookie's Avatar
udfxrookie
I've seen some of the other postings, especially from Ali... And now I'm wondering if I was supposed to wire the crank sensor differently (I've read somethings about the Black wire from the distributor plug is the crank position signal
and should go to the crank sensor to read the 12 teeth and the white being the common ground for the dist. & crank sensor and to splice into this one and run it to the crank sensor....
The plug going to my distributor cap is:
Blue wire - Pin 27B -Crank Signal (NE)
Red wire - Pin 26B - Cam Signal (G1)
Yellow (might've been white lol) - Pin 25B - Cam 2 Signal (G2)
Black - Ground
Old Sep 7, 2024 | 08:10 AM
udfxrookie's Avatar
udfxrookie
SUPER Excited.... So I did the wiring.... from Distributor to the Crank sensor on the GTE oil pump and I now have Stat Sync and the car sounded like she was ready to come alive!!! Whoop whoop...
Guessing timing may be off, waiting on AEM to reach back first with the logs I sent them... If any here are familiar I'm attaching (and uploading as zip) my logs for review, and help.
First one is the Start page log:
https://drive.google.com/file/d/1saF...usp=drive_link
Second is the Advanced Pickups tab:
https://drive.google.com/file/d/1xne...usp=drive_link
File Type: zip
Old Sep 8, 2024 | 09:31 AM
udfxrookie's Avatar
udfxrookie
Old Sep 9, 2024 | 10:17 AM
udfxrookie's Avatar
udfxrookie
Got it started and now I have no spark on cylinder #3 smh
Old Sep 9, 2024 | 04:19 PM
udfxrookie's Avatar
udfxrookie
---Solved with new wire set---
VIPDreamin
Mar 11, 2022 06:13 AM
Doss300
Maintenance
Feb 12, 2022 12:44 AM
Tugrol67
Feb 6, 2020 07:25 PM
AWDtoyota
Performance
Jul 23, 2013 06:57 AM
carbongs
Jul 14, 2008 06:24 AM
