'95 ECU Replacement - Not Starting
Just replaced the engine ECU in my '95 SC400 with a rebuilt unit from All Computer Resources in FL, and now there's no CEL and it won't start - just cranks. I see where other folks have had the same issue, and looks like the likely fix is to get a new ECU. Just curious though, what is the real underlying cause? Did they program it incorrectly? Could it still have a faulty component? Just wondering why this is a common problem...
Hello,
Do you have Spark and Injectors?
No CEL when the Ignition is in the ON position is a solid sign that either the bulb is burnt out, or that the ECU is not functioning, I would contact the place that did a rebuild to see if they offer warranty repairs if it's not too late, and if not, you will have to find a different place.
Tanin Auto Electronix is a highly regarded place around here, I myself haven't worked with them, so I can't speak for the quality, but it is a place to start from all the positive reviews that are out there, in fact, they also have an account here on this forum.
Hope this helps and best of luck!
RudysSC (03-06-23)
Hello,
I've used Tanin before, they're just a little pricey. Same ECU is almost 3x as much.
RudysSC (03-06-23)
We are not aware of any other companies that actually plug your repaired ECU or any refurbished ECU that they have in stock into vehicles to ensure proper function like we do. If they did you wouldn't be having this issue. It's just an extra step we take to avoid back and forth.
With that said, we aren't looking to steal business from other companies. We are here if anyone needs us.
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
262-456-4147
The climate control module I purchased from Tanin has been rock solid - no issues. Wish these cars didn't have so many darn computers.
RudysSC (03-07-23)
