Pacific For events in California, Idaho, Nevada, Oregon, Washington, Hawaii, and Alaska.
The Unofficial WA BS thread
Old Mar 17, 2010 | 06:00 PM
  #826
S30ZG's Avatar
S30ZG
lol fyi the 30 mm spacers have extended studs protruding from the massive hunk of metal. And drksyde are you by any chance selling those 15mm H & R spacers? I need to space out the fronts a lil bit more.
And you can also get some hub centric rings if your spacers don't come with a hub centric bore.
http://www.justforwheels.com/index.jsp?cat=hubcentric
Old Mar 17, 2010 | 06:18 PM
  #827
drksyde's Avatar
drksyde
sorry, I actually use them for my stock wheels to clear my bbk when I need to drive in the snow.
Old Mar 18, 2010 | 07:22 AM
  #828
sway162's Avatar
sway162
Originally Posted by drksyde
without the hub centric ring, the wheel may not be aligned correctly making it spin unevenly causing vibrations when you drive. That is true that some cars do not require hub centric rings but my car (IS300) has a hub centric ring stock so I would think it is there for a reason. Otherwise, why would our cars come with the hub centric rings in the first place?
If you get a thin spacer, it is thin enough that the stock hub centric ring is still being used. Be very careful when using the "cheap spacers" because I have gotten some before in the past and they were unevenly machined causing vibrations. The vibrations can cause damage to wheel bearings (trust me, its not cheap to replace) and sometimes if your wheel is spinning unevenly due to uneven machined spacers and POSSIBLY from not having the hub centric ring... your wheel studs will break... I know because I have already been there and done that.
Thanks for the info bro....appreciate it.
  #829
sway162's Avatar
sway162
Nice, good lookin.
Old Mar 18, 2010 | 11:52 AM
  #830
drksyde's Avatar
drksyde
Originally Posted by sway162
Nice, good lookin.
Those hub centric rings are for aftermarket wheels that didn't come with it
Old Mar 18, 2010 | 12:58 PM
  #831
LEXveryG8's Avatar
LEXveryG8
Screw the zoo jk....Northwest Trek fellas!
The Honolulu Zoo was coo when I was there back in the day! haha
lol I'll be sure to check it out.
Old Mar 18, 2010 | 01:38 PM
  #832
IS3_FTW's Avatar
IS3_FTW
Yup, everywhere I read said to get extended studs anything over 5mm. I have Ichiba extended studs on it's way to me. =)
Has for hubcentric rings...I'm hearing that they are overrated and only really necessary for anything over 15mm.....This is from my research so far though.
What does your Ichiba spacers look like? Are they not the v2 ones?
Old Mar 18, 2010 | 01:53 PM
  #833
sway162's Avatar
sway162
Yup...I know.
Old Mar 18, 2010 | 01:55 PM
  #834
sway162's Avatar
sway162
Nah...they are not Ichibas. I ordered a set of Ichiba extended studs though for 8mm that I will get soon.
Old Mar 22, 2010 | 05:43 PM
  #835
is300chris's Avatar
is300chris
CL Folding 25,000
going to practice my photo skills tonight
Old Mar 22, 2010 | 07:00 PM
  #836
S30ZG's Avatar
S30ZG
want to practice them on my car? aha i need some legit photos taken.
Old Mar 22, 2010 | 07:56 PM
  #837
benr33tz's Avatar
benr33tz
I need some bigger wheels and super aggressive fitment kthxbye
Old Mar 22, 2010 | 08:58 PM
  #838
LEXveryG8's Avatar
LEXveryG8
Wow the weather was great today, loved it!!!!
Old Mar 22, 2010 | 10:37 PM
  #839
IS3_FTW's Avatar
IS3_FTW
the weather down here was scattered clouds. but warm also
Old Mar 23, 2010 | 12:08 AM
  #840
LEXveryG8's Avatar
LEXveryG8
Nice, did you guys get some sunshine too?
