Radio Station Presets
Brand new 2019 NX owner here. In my previous cars, I'd select the band with one button, then cycle through the presets 1 through 6 on just that band. On this car, it appears I cycle thru all 12, or even up to 36, presets regardless of the band. is there a way to set saY 6 AM and 6 FM presents, but cycle thru just the ones on that one band?
No, you can select in groups of 6 up the max # of presets. You an put them in any order you want regardless of band. But, if you select 12 as the number of presets you will run through all of them in the order you selected them unless you use your touchpad or joystick. If so equipped you can use voice commands to tune to the station you want. When using Sirius you can say "tune to channel 50" and it will go there on its own. Not sure how it works on AM or FM but can't imagine it can't be much different. (I only use Sirius)
There's 2 different ways to sort your presets.
1. You can use "Mixed Presets" and you'll get 36 preset slots. Using Mixed you can have AM, FM and SAT stations all mixed together. You could also program them so they are grouped together by band.
2. You can also use "Individual Presets". Those will separate presets by band like you are used to. You'll get 12 presets for each band I believe. But you would have to switch to a different source if you wanted to switch to a different band.
Voice commands are the best bet
