NX - 1st Gen (2015-2021)
Is it possible to disable Sirius XM?
Old 02-05-19, 12:52 PM
kubakj
kubakj's Avatar
Default Is it possible to disable Sirius XM?
I am not subscribing to it, is it possible to disable so it wont turn to it?
Old 02-06-19, 05:16 PM
MKenM
MKenM's Avatar
What do you mean by "it won't turn to it"? Two things, if you don't subscribe to XM the only channel you can get is channel 1 which is just a channel with a mix of music and mostly ads for subscribing. The second is if you don't select XM on your radio you won't see it unless it is in your music channel list for AM and FM stations. If the latter is your issue just over write those channels with AM of FM stations.
Old 02-07-19, 05:06 AM
slypx
slypx's Avatar
You may also want to reorder the way they are ordered in source selection ... this way it will only show up last when changing source from the steering wheel button
Old 02-08-19, 04:46 PM
MKenM
MKenM's Avatar
Guess it depends on what year NX you have. I don't see "Reorder" on my vehicle.
Old 02-08-19, 04:50 PM
slypx
slypx's Avatar
mine is a 2018... I would suggest that you look it up in your own owner’s book to find the specific for your model and year
Old 02-08-19, 05:09 PM
MKenM
MKenM's Avatar
Mine is a '16 and I have searched the PDF of my owners manual using the find command for "Reorder" and it apparently must be something on newer Lexus models.
Old 02-09-19, 08:13 AM
mcomer
mcomer's Avatar
Answer to the OP question is no. You will always have each of the Modes AM & FM & XM
whether you are tuned into a station or not. AM will play static, FM might be silent and XM
will just remind you to sign up.
Old 02-09-19, 03:58 PM
slypx
slypx's Avatar
From the 2016 user guide found online ...
MKenM (02-09-19)
Old 02-09-19, 06:26 PM
MKenM
MKenM's Avatar
All the while I was looking for the word "Reorder" instead of "Rearranging" Thanks again!!
Old 02-12-19, 12:05 PM
kubakj
kubakj's Avatar
I just wanted to remove/hide this source, that when I drive and switch modes/source it will not go to sirus as I dont subscribe to it.
blubox (03-26-23)
Old 02-12-19, 04:25 PM
MKenM
MKenM's Avatar
As @mcomer has stated above the answer is no. Do you subscribe to Slacker or Pandora, use an iPod or USB?
Old 02-13-19, 12:10 PM
GS3Tek
GS3Tek's Avatar
On my 2011 sienna, I unplugged the xm antenna. I also like to scroll through my sources on the steering wheel so it skips through the xm.
I haven't done it on the NX to see if it skips through it.
brook41 (02-13-19)
marinrain
Hybrid Technology
09-24-15 10:47 AM
InRBigness
RX - 3rd Gen (2010-2015)
12-19-11 10:33 AM
unreeaal
04-26-10 10:21 PM
Belmont
07-13-06 08:32 PM
Quick Reply: Is it possible to disable Sirius XM?
