Rear Hatch Won't Open Using Dash Button
If I step out of my vehicle, in park, engine turned off, I should be able to open my vehicle with the fob in my pocket. This is basic logic. No amount of obtuse programming will convince me otherwise. Another possible safety aspect is when I fly off a bridge and the front of the vehicle is downward due to engine mass, water is entering the vehicle , the windows do not work because someone has locked them and the battery is now short circuited disabling all electrics including windows.I've floated to the surface next to the rear door, where my groceries are now floating because I paid to much for an expensive poorly programmed vehicle. I want out...right now before I drown...where is the handle?
Your knowledge of the principles of physics is simply astounding. I am sure your grade school teachers were suitably impressed. Unfortunately, when parked outside, not typically the trunk does not open with fob in pocket which is, in fact, the issue being described. How do you suggest I get my groceries? Break the window? Or is the air pressure too high?
My rear door will open with the FOB in my pocket by holding the button on the rear door for a couple of seconds. It will also open if I use the FOB and hold the FOB trunk button for a couple of seconds. If I’m in the car and the doors are unlocked, the button on the dash will open the rear door if I hold it a couple of seconds. It will not open if the doors are all locked. If yours does not do this, you need to visit the dealer and let them fix your car.
My rear door opens when the vehicle is locked, from either the fob or the rear handle. It always opens (under any conditions) from the button on the dash.
What I find frustrating is that when trying to open via the rear handle, sometimes it takes several tries to get the hatch to open. Even though I'm pressing the left side of the button, sometimes it wants to lock the vehicle, even it it's already locked. My wife had an RX350, with a rear-door hydraulic assist, but no electronics. That worked every time, and without the annoying (and very loud) beep.
jianbinw
NX - 1st Gen (2015-2021)
01-09-16 09:25 AM
