run flat tires
unlikely any 17" will clear the calipers. you can test fit it (make sure to do it front and back if you do). even for 18", depending on style..you may be cutting it close without a test fit. or be willing to shave your calipers
Thanks will give it a try in the Fall time
2022nx here. I have no idea what people are talking about when they say run flat are a bumpy ride. First vehicle I’ve ever owned with run flat and there is no difference in the ride. What I don’t like is, the tires are $500 a pop and can’t be repaired like a non run flat can.
Run flats really can't be repaired, and regular tires are much less than $500 per tire. There were only a few 235/50 R20 regular tires but now there are quite a few and more and more every day.
Your choice, but to me it is a no brainer.
YMMV,
MidCow3
they don’t last long if you run over a nail. And I’m currently in the midst of my first scare. Weather just got very cold recently so I know that plays a factor but out of the blue my driver rear dropped 3psi. Put air in it today and I’m hoping I’ll be ok. If not, $500 right out the window.
I mean at the end of the day you have no choice. That’s what the vehicle comes with. When I need new tires I have the option to switch. I would never opt for run flat tires but again I had no choice. I could’ve purchased the tire and wheel insurance for $2500 but I had that on my last vehicle for $1800 and did not get my moneys worth so I passed. Tires are $500 a pop and the wheels are $1000. I have the cloudburst f sport with the black wheels. Beautiful vehicle, the run flats make me nervous. Another factor is the roads in the northeast where I live are not the greatest.
Such negativity. I can't believe Lexus would provide run flats as standard equipment without good reason. I've only had my NX a few weeks but I must say this is the quietist, and smoothest ride I've ever had. So far I love them.
agree 100% about the ride. It’s perfect, I notice no difference. My only gripe is they can’t be repaired.
Same here - going to run them as long as I can and then replace, most likely with Michelin CressTrek as we live in snow country. For now, I'll use during warmer weather and change out with winter tires for another year or two, providing we don't get have an issue with run flats (i.e. a tire that's not repairable).
To be truthful, you really can't make the statement "I notice no difference" because you have not driven a 2022 or 2023 Lexus NX with regular tires.
Run flat tires are heavier and stiffer and by all physical and scientific indications would not run as smooth as a lighter more flexible tire. It my be awhile , since I don't drive a lot of miles, but when I change to regular tires <i.e. non-run flat> I will give you my honest humble opinion of the ride differences and other differences between the two tire types.
Peace and Good Will
YMMV,
MidCow3
You say you notice no difference, so you have also had regular tires on your NX.? If so why oh why did you change back to run flat tire? The riding dynamics and suspension of the NX are such that the NX rides very well EVEN on run-flat tires.
Peace and Good Will
YMMV,
MidCow3
Peace and Good Will
YMMV,
MidCow3
