Premium gas vs regular
I read some of your posts on the cost difference and it made a lot of sense. In my opinion, I would not cheap out on a lower grade engine oil in my luxury cars, why would I used a lower grade gas.
If there is a quantifiable test difference, then using the recommended octane is not useless. Lexus recommends 91 octane for the NX350h, no where in owner’s manual does
Lexus recommends 87 octane, it just say you could use it with reduced performance. I tend to use what the manufacturer recommends, especially if the cost is not a big factor.
One possibility is that in Japan the regular is about 85.5 AKI (using US units for consistency).
And the higher grade is about 93.5 AKI.
So it's possible the Japanese manual started saying this because of the lower octane of their regular fuel.
Then the translated manual would have kept the message even though the US regular has a bit higher octane rating.
In AKI we have:
US: 87 or 91
JP: 85.5 or 93.5
But other cars using the A25A-FXS are fine with 85.5 AKI in Japanese manuals...
When unleaded premium gasoline (unleaded high-octane) is not available, unleaded regular gasoline may be used, but the following conditions may occur:
- Abnormal noise or vibration from the gasoline engine (knocking)
- Reduced gasoline engine output
In AKI we have:
US: 87 or 91
JP: 85.5 or 93.5
In AKI we have:
US: 87 or 91
JP: 85.5 or 93.5
In AKI we have:
US: 87 or 91
JP: 85.5 or 93.5
My questions is, is been able to take advantage of the higher octane 91 the same as using 87 is not good for the engine? I believe the specs on the 2.5 on the RAV4 & NX350h are the same, HP & torque, & the RAV4 recommends 87. It looks like they are "tuned" the same? Not sure what extra do you get by using 91.
I wonder why if the car is tuned for 91, still has the same HP & torque specs. I was under the impression that the 2.5 L in the 2025 NX250, is the same as the 2.5 L in the 2026 NX350h, Ie. same HP & torque; differences in HP is because of the electric motor. I would expect that with the higher octane you should get @ least more HP.
- Front Motor (MG2): 134 kW (180 hp) and \(270 \text{ Nm}\) (\(199 \text{ lb-ft}\)) of torque.
- Rear Motor (MG3): 40 kW (54 hp) and \(121 \text{ Nm}\) (\(89 \text{ lb-ft}\)) of torque.
I guess a simpler analogy, during casual/calm usage the 2.5L engine sort of acts more like a 1.6L engine when drawing in air and injecting fuel, but acts more like a 2.5L engine when the air/fuel mixture is being burned. I suppose you could think of it partially similar in purpose to a cylinder deactivation technology some manufacturers use, but a lot less stupid. This creates substantial increases in economy and lowering emissions, but the side effect tends to be lower HP and torque (which is handled by electric motors). Gas engines have traditionally not used this because the drop in HP and torque was excessive. Over the years the design development coupled with computer control have allowed the differences to narrow, but they are still present (otherwise all cars would use hybrid engines, whether actually hybrid or not)
One of the reasons that hybrid trucks and performance hybrids are now often using turbo engines, despite the benefit of instant torque electric motors for assistance, its hard to beat the torque of a forced induction engine once it gets spinning while meeting economy and emissions targets (EVs with giant batteries aside).
Not only tuned differently, but they are also mechanically different engines. The short block (ie block, crank and pistons) are substantially the same (the A25A part of the engine designation), but the cylinder heads are different (the following 3 letters in the engine designation, FKS, FXS, etc designations). Hybrid engines (well, conventional ones designed for economy) use a cylinder head with a higher static compression ratio but at the same time the valve timing is much wider (the range during engine rotation where the valves will be open or closed). The purpose being the engine can be controlled to take in a lot less air, so needs less fuel, but the higher static compression still supports good combustion in this situation while having the benefit of the larger space within the cylinder for fuel to cleanly burn and expand more thoroughly to extract a wee bit more power from the tail end of the combustion process (gas only engines tend not to do this because they can't afford to wait around all day for this to happen, LOL).
These FKS, FXS engines seem to be quite robust and of high quality, so far. Class leading thermal efficiency too. I know there's next generation 1.8 and 2.0 litre engines forthcoming based on FKS, FXS technology from Toyota.
