NX - 2nd Gen (2022-current)
View Poll Results: When did you have your 12V battery replaced (first time, if multiple)?
Hybrid: 12V replaced 0-18 mths
16.67%
Hybrid: 12V replaced 18-36 mths
7.41%
Hybrid: 12V replaced 36+ mths
0%
Hybrid: 12V NOT replaced 0-18 mths so far
18.52%
Hybrid: 12V NOT replaced 18-36 mths so far
20
37.04%
Hybrid: 12V NOT replaced 36+ mths so far
11.11%
Gas: 12V replaced 0-18 mths
0%
Gas: 12V replaced 18-36 mths
1.85%
Gas: 12V replaced 36+ mths
0%
Gas: 12V NOT replaced 0-18 mths so far
3.70%
Gas: 12V NOT replaced 18-36 mths so far
1.85%
Gas: 12V NOT replaced 36+ mths so far
1.85%
Voters: 54. You may not vote on this poll
12V battery life poll
Old Aug 13, 2025 | 11:41 AM
rch's Avatar
rch
I have battery monitor with history, it just doesn't go to low state of charge. I can see quick dips in the history graph as expected from momentary load like hatch operation, but it settles back to normal 12.4-12.65V if left alone, as expected. A/C is on all the time. Didn't try max heating, too hot here.
I would like to know what special can be done to bring 12V down (other than stupid things like staying in ACC mode with lights on) so that I would not end up with discharged battery by accident as many. But so far I didn't seen anything. Maybe it's about already sulfated batteries in bad shape unable to take quick charge as designed.
Or maybe it's something with Japanese battery OEM (Yuasa or Panasonic?) quality, I think it has lower CCA which should affect quick charge ability as well. Then it would be specific to J* VIN cars.
Old Aug 13, 2025 | 12:13 PM
NX450Guy's Avatar
NX450Guy
Man, if it hasn’t happened to you yet, you’re probably fine with how you drive/use the NX. I wouldn’t worry too much, just have a portable jumper on board uncase a “stupid” day arrives. Would be interesting if there was some sort of data base on which batteries were involved in the sudden discharge and see if there is a pattern. I’ve been problem free after the first three months and learning how to make sure my battery gets a full charge.
jironman
LX - 4th Gen (2022-present)
Jan 25, 2025 10:52 PM
SLYNX
Apr 23, 2024 07:18 PM
MX73
Mar 7, 2022 10:17 AM
RAMAIR
Aug 31, 2017 02:31 PM
