NX - 2nd Gen (2022-current)
350h charging points.
Old Nov 1, 2025 | 12:27 PM
  #31
BillKZ's Avatar
BillKZ
^^^ Because making and installing that many stickers would bankrupt them!
Easier would be just two stickers - one showing where to ground (even though there are several safe points, just pick one), and a a big “POS JUMP IN FUSE BOX” sticker.
Old Nov 1, 2025 | 04:02 PM
  #32
oreon333's Avatar
oreon333
Why they should bother with not to jump stickers/labels for some silly people, when they clearly showed where to connect your + and -
Old Nov 1, 2025 | 04:06 PM
  #33
Freds430's Avatar
Freds430
Did not know this.
Old Nov 2, 2025 | 10:04 AM
  #34
TheCDN's Avatar
TheCDN
Well first off by all the comments that show up on this forum, I'm certain there's quite a few people that haven't got a clue what a manual is, where to find it and how to read it. So they go to Google and see there's a Lexus forum they can go to to get someone to answer their question.
They've bought a car costing thousands of dollars and think they can treat it like a refrigerator (the simple ones that don't even need to replace those water filters). end of rant
Old Nov 2, 2025 | 11:18 AM
  #35
Korrigan's Avatar
Korrigan
And that guy in the video above really needs to read the manual.
Old Nov 2, 2025 | 12:21 PM
  #36
glennhl's Avatar
glennhl
Originally Posted by Lexicon1
Well, some think frying the ECU is a "Rumor". Perhaps those that think its a rumor should "test this theory"
LSFT, perfect video update...which tells us where NOT to connect the Negative terminal.... no more guessing, no more "groundless claims"..... : )
Lexicon1, I did what you said, I tested this theory and guess what, you are absolutely correct. Now the car won't start and there is a strong burnt smell coming from the ECU. Oh, by the way, Lexicon1, you have a really nice car, but you will need to call a tow truck to get it towed.
Old Nov 3, 2025 | 11:55 AM
  #37
DampDuffer's Avatar
DampDuffer
Originally Posted by gamma742
While we at ClubLexus know better than to ground it incorrectly. I have to think that some in the general public have had AAA or someone with less experience jump it incorrectly. After all, we know how frequently the 12v fails on this model.
I hear all the time of batteries getting replaced but no ECUs.
Oh, for sure!
When AAA came to jump my battery last spring, I was told, "this may be the last time we are going to be allowed to do this because too many tow truck guys are frying the electrics on these Lexus hybrid cars."
Old Nov 3, 2025 | 12:14 PM
  #38
DampDuffer's Avatar
DampDuffer
Originally Posted by Freds430
Uh-oh!
That's not the way my Lexus support guy did it on the two occasions I needed a jump start.
He never went to the actual battery, and as has already been pointed out, that is not how the process is described in the manual.
Old Nov 3, 2025 | 01:36 PM
  #39
Freds430's Avatar
Freds430
Originally Posted by DampDuffer
Uh-oh!
Everybody that does not have a hybrid jumps it from the battery.
Old Dec 26, 2025 | 08:11 PM
  #40
midcow3's Avatar
midcow3
Lightbulb
Originally Posted by Korrigan
This video is incorrect. The resistance between the ECU bolt and the engine frame is 0 ohms meaning it is the same metal ; no difference. ECU failure is cause by incorrectly connecting the order of jumper cables see this thread for an explanation: https://www.clublexus.com/forums/nx-...-failures.html
YMMV,
Miccow3
Old Dec 26, 2025 | 08:15 PM
  #41
midcow3's Avatar
midcow3
Originally Posted by lsft
There is a follow up video that shows clearly from Lexus where to jump start
https://youtu.be/HpXu9uoOeuw
YMMV,
Midcow3
Old Dec 27, 2025 | 06:50 AM
  #42
lsft's Avatar
lsft
YMMV,
Midcow3
Thanks for your input on this matter. But Lexus/Toyota documentation states different and this is coming officially from the OEM where NOT to clamp the negative. Again, as you stated if you can boost from the metal bar from the engine that would be the most safe place.
Old Dec 27, 2025 | 10:05 AM
  #43
TheCDN's Avatar
TheCDN
The simple fact is current will change all you theoretical assumptions that there is a good ground with a bolt or nut head. How the heck do you think a fuse works!!! Good ground yup, a lot of amps, oh crap! the fuse blew! no ground now, I melted so you wouldn't ruin your equipment on this circuit! Well a simple tiny piece of metal like a tiny bolt head is never a healthy ground to choose to jump a car! Electricity will always find a path of least resistance. Follow the direction of the Manufacturer of the car, full stop! Otherwise you're on your own, zap away senseless people.
Old Dec 28, 2025 | 12:20 AM
  #44
hintonwood's Avatar
hintonwood
I still think that the simplest solution is to lengthen the Earth lead on the booster and use the designated earthing point on the engine:
https://www.clublexus.com/forums/nx-...t#post11808113
playlaguna
Performance
Nov 13, 2017 04:54 PM
podlesnick
RX - 4th Gen (2016-2022)
Jul 28, 2016 07:01 AM
tecman
GX - 2nd Gen (2010-2023)
Feb 20, 2015 04:29 PM
aloha08isf
IS F (2008-2014)
Jan 25, 2009 09:40 PM
50loser
Maintenance
Feb 26, 2005 06:08 AM
