NX - 2nd Gen (2022-current)
Interior Engine Sound Level Adjustment?
Old Feb 12, 2024 | 05:19 AM
  #46
Zlobix's Avatar
Zlobix
Originally Posted by kiska3463
Хорошо
, даже если вы перейдете к параметрам apk gen1 и gen2, я не вижу эту опцию.
Может кто-нибудь это подтвердить?
Спасибо
Do you see other options in Carista? Can you change them?
It probably matters how you connect the Carista to the car.
1.The car is completely turned off.
2. Insert the OBD II adapter.
3. Turn on the ignition (multimedia and climate control will start, but the engine will not start)
4. Launch the Carista program and connect it to the OBD II adapter.
5. Wait until Carista connects to the car.
After this, you can change options in different sections of Carista.
Old Feb 12, 2024 | 05:28 AM
  #47
Zlobix's Avatar
Zlobix
Originally Posted by Xanadu350
I still don’t understand how this app Carista gets access to Lexus electrical/engine pc module in vehicle? Will it void your warranty if dealer finds out it’s been re programmed?
You need to follow the steps I described above.The dealer may see these changes, but only if he specifically looks for them. Why he needs this is not clear.In order to deny your warranty, the dealer must prove that it was this change in the parameter that led to the occurrence of a warranty claim.Toyota/Lexus cars do not strive to record in detail all changes in the car software, so it is unlikely that the dealer will look for changes at all.In VAG cars everything is different, changes in settings are recorded there, but even there the dealer does not bother himself with searching for these changes.
whlng88
Nov 23, 2021 03:49 PM
t100toyota
GX - 1st Gen (2003-2009)
Oct 21, 2021 01:07 PM
KuroYuki
Jun 19, 2020 02:02 PM
fmast342
LS - 5th Gen (2018-present)
May 29, 2020 11:23 AM
karlonas
Nov 4, 2015 01:10 AM
