NX - 2nd Gen (2022-current)
Nav Destination traffic display issue
Old Dec 1, 2023 | 11:44 AM
lf4318's Avatar
lf4318
Default Nav Destination traffic display issue
Suddenly after almost 2 years on my 2022 NX 350 Luxury when I put in a destination on the nav screen it now longer shows the traffic on the route I am travelling.
Used to show various colors depending on the traffic- blue when no traffic, red, dark red, yellowish etc. Now only a thick blue line. When no destination is chosen I get the usual thinner lines with the various
colors depending on the traffic. Have the same issue with the 2023RX 350H suddenly.. When there is a destination chosen it does shows traffic conditions on the various streets, highwas etc.
so the system is picking up the traffic. Anyone else noticing this issue?
Old Dec 1, 2023 | 05:07 PM
kent2174's Avatar
kent2174
I was on congested I5 going to LA other day. Very disappointed I cant view traffic colors/conditions after destination was chosen. Hope not a reason to use carplay.
Old Dec 2, 2023 | 10:23 AM
SeismicGuy's Avatar
SeismicGuy
I don't have the native Lexus nav app and had not made up my mind about subscribing. But sort of tangentially related I do have some minor issues with the nav/maps I am using through Android Auto from my Galaxy S23. I sometimes use Waze and sometimes Google Maps. In either case there is no way I have found to just get a 2D view from the perspective of the car going upwards on the view with the map turning as the car turns (not sure if I explained that well). I get the 2D view with north upwards but the view I want where the map turns is only available on the 3D views from Waze or Google Maps. The other minor annoyance is where the auto marker ends up with respect to the overall display. I like it to be horizontally in the middle of the map display which is the case when you have the gridded view (i.e., map plus the audio tiles to the right). When I touch the map to expand to the full display the little auto marker get shifted to the right rather than being in the center. I think it has something to do with the little "search" box at the upper left of the map. When I "compress" that and the previous locations disappear, the auto marker will shift leftwards back to the middle. BUT this is not always the case and where the marker ends up is sometimes in the middle and sometimes shifted right and it seems rather random.
Again not sure if I am explaining this well and might try to take some shots of the display next time this happens. But my real goal is to find out if there is a way of having the map orientation that occurs in the 3D view also in a 2D view without having to select north upwards (I think others have called this "2D Heading Up")
Thanks.
lf4318
RX - 5th Gen (2023-present)
14
Feb 15, 2025 07:30 PM
Alant514
Jun 27, 2016 09:23 AM
akshunj
Apr 22, 2015 02:22 PM
vladbph
Sep 29, 2007 05:01 PM
hhijim
Dec 14, 2006 09:54 PM
