Power Liftgate questions/issues (Merged threads)
Hi all--
Does anybody know if there is some sort of obstacle detection for the power rear door/lift gate?
I.e. if there is something in the way will it not open or will it open anyway and cause damage to the tailgate?
I've read through the manual and cannot find an answer. Thanks!
Hi all--
Watch the video at 8:04. Should answer your question.
All-new Lexus NX 300h compact SUV FULL REVIEW test driven 2016 - Autogefühl - YouTube
What if there's a small child standing near the rear hatch with the door descending. Does it act like a guillotine.
Surely there must be a safety trip at some pressure point?
But seriously I was shocked too. I would have thought that they would have thought of that? This is not just Lexus, but they guy said that other brands also have this issue.
It's funny because such mechanisms exist. In the RC F (and other high end sports coupes) with electric seats will retract back forward if the seat is impending on the rear passengers knees.
Mine stops if something blocks the rear door. It takes a little more pressure then your arm in the way like in the video but I cannot see it injuring, let's say an 8 yr old child. I just wish it worked a lot faster, like a manually operated hatch that can be opened or closed in a couple of seconds. The NX takes 12 seconds from when you press the button to the hatch being fully open
Page 125 of the '15 manual:
● When the power back door automatically opens, if an abnormality due to people or
objects is detected, operation will stop.
I tried it once and it did stop during a close. Also, pressing the door switch again stops it.
If you don't mind doing it manually, you know there is an option in the display in the instrument cluster to disable to powered tailgate and open it manually instead?
That is such a lie... Not from you, but from Lexus. I've tried it, and on mine when you turn off the power, you feel as if you're fighting the motor to open the hatch. Like if you pull up on it too hard you're going to break it. Anyone else have this experience?
I heard from other people too about this. I personally haven't tried it, but I will try that tomorrow and see what it feels like.
Ok, hypothetically if there is a garage door in the way. Would your door stop or would it hit the garage door (thereby damaging your car/garage) and then stop?
It would hit the door. As you can see form the video, there is no sensor as it approaches an object, it only stops when there is enough force to stop it in its way.
There is a setting in the menu to set the height of the lift gate when it opens. Once set it won't go above that limit so it won't hit the garage door or ceiling.
And yea, you can turn off the power feature but it does not disengage the motors so opening and closing becomes difficult
it does require a good amount of force before it stops opening - way more than what I would expect. I had to set the opening to the middle value or else it will hit my garage door. I have to duck a little when putting things in the back.
The reason is that when I'm out and about, I used to bump my head on the not-opened-all-the-way hatch. (I'm used to it now, I know to duck a bit).
Having said that, you can push the hatch open all the way, if needed. I don't know if pushing it up is bad for the hatch motor or its related components, but it sure feels like I'm forcing something that shouldn't be forced.
2016 nx200t Awd, non fsport
A few months ago when I opened my power trunk/liftgate, the driver side piston made a loud noise and snapped out of place making a dent and prevented the trunk to open all the way. I have to manually open the trunk all the way and place the piston back into its position where the ball bearing is. I'm not sure if you guys understand what I'm trying to describe.
So I decided to bring back to Lexus dealer and see if they can fix the problem or replace the lift support. When they were checking it out, everything was fine. They said they added some grease or oil, but nothing was replaced. Just last night I opened my trunk again, same **** happened again on the same side.
Do any of you encounter the same problem? I don't even open the trunk much. Is it because I adjusted the height level to its maximum? (Which is at 5 I think). Maybe i should lower the height level to prevent this from happening again? How can these trunk strut snaps out so easily on a Lexus?! I only owned the car about 14 months with the first time happening during my first year.
I will ill upload some pics when I have a chance.
thank you.
thank you.
