Dynamic Cruise False Lane Departure
I have an NX300, 2020 model year.
When using dynamic cruise control we get frequent and annoying steering wheel vibrations/tugs as if we're out of our lane, but we're not. When dynamic cruise is off, this doesn't happen, we get appropriate lane departure vibrations/tugs. Any suggestions? Trying to reach our technology specialist, but no response so far.
Check to see if you are in "Follow-up Cruising" mode. If so, and the vehicle in front of you sways, then your car will sway, as well.
Other items to consider...
- Check if the "Lane Centering" function is turned on—which is different than the "Steering Assist" function.
- Check to see if the "Vehicle Sway" system is turned on. In my UX, the menu icon is a coffee cup. Although I believe this just results in a warning alert, not a steering correction maneuver.
Yes that is the lane centering function in action. Is only active when using radar cruise control. It's actively trying to keep you in the center of the lane. So you'll feel it make little adjustments as you drive along. You can turn off just the lane centering function.
Thanks for the response in explaining the two different functions. I had tried out the dynamic cruise control for the first time the other day, and notices that what I thought was the lane-keeping assist being much stronger.
Renegade27
11-26-19 05:15 AM
DavidZ
ES - 7th Gen (2019-present)
17
08-13-19 07:13 AM
satiger
11-02-17 05:49 PM
