NX - 1st Gen (2015-2021)
Need Some Help
Old Apr 18, 2019 | 05:34 PM
2017FSport's Avatar
2017FSport
Default Need Some Help
I am about ready to pull the trigger on some wheels for my new ride and need some help from you guys who have switched from stock. I am planning to run these http://www.asantiwheels.com/asanti-b....htm?type=5806.
here is my dilemma, if I run the 8.5" wide with 38mm offset then it will only push the wheel out towards the fender 10mm. which isn't enough to get it flush. but if I run the 9" wide with 35mm offset it pushes them out 19mm. which may be too much on the front? can I run the 9" wide wheel and it not stick out? I plan to run 245/45/20 tires if that matters.
has anybody fit a 9" wide wheel on the front with 35mm offset? if so, do you have any pics? thanks in advance.
jc11
Oct 13, 2011 11:05 PM
Choiza
IS - 1st Gen (2001-2005)
Nov 19, 2009 02:20 PM
dboyz85
Aug 30, 2009 11:54 AM
NCDUB
Jul 26, 2009 04:39 AM
bluerex
Sep 30, 2007 12:32 AM
