NX - 1st Gen (2015-2021)
Ran over a palm tree frond....any damage?
Old Aug 19, 2018 | 11:43 AM
WhatYaGot's Avatar
WhatYaGot
Default Ran over a palm tree frond....any damage?
Hi, the wife had no other choice, but to run over a palm frond. I've only changed the oil once, so I'm not too familiar with the undercarriage of this vehicle. Is the passenger side (left side of the picture) missing any lower covers? Does anyone have a complete underside picture that shows underneath from the left and right front wheels to the front bumper?
Old Aug 20, 2018 | 02:51 PM
ukrkoz's Avatar
ukrkoz
Don't think so. I just did oil change on mine, looks pretty much stock.
Also, you have plastic oil filter cover. You may consider replacing it with Dorman metal one.
Old Aug 21, 2018 | 03:57 AM
nigel821's Avatar
nigel821
Arrow
The Dorman doesn't fit the 2.0L engine does it? I know Toyota makes an OEM metal housing but pretty sure it's for the 2.5L engine and not the 2.0L.
-Nigel
Old Aug 21, 2018 | 10:11 AM
olgzr's Avatar
olgzr
It’s the same housing and filter that’s on the 2009 Toyota Venza (4 cylinder) we traded in on this car. That had 120K miles with oil changes by me every 5K miles and no problems with the “plastic “ filter housing. We’ve got 35K miles on our NX and no problems with the filter housing so far. I don’t see a need to buy an aluminum housing unless it’s for “bling”.
Old Aug 21, 2018 | 12:42 PM
ukrkoz's Avatar
ukrkoz
We had several Highlander owners who reported that filter cover crack. When I did my oil change last week, it was torqued so much that I had to buy special wrench to undo it and even with that took me a lot of effort to undo it. Bling is great idea, especially if it's in a spot where no one can see it, right?
Yes, Dorman fit my NT just fine. Also, they had it with missing part, center flat cap. I took chance that OEM one will fit - and they gave me 50% discount on it. So I landed with both special wrench for those filters and Dorman metal cover $27 out da door. And indeed, that center cap - drain - fit into Dorman just fine.
I had same Dorman replacement on my Highlander. I respect others opinion and experience but I do not get along with plastic anything in that area. If you DIY oil changes, I bet you hand torque it, right? Not use power tools or something, judging by how hard it was to remove it after Toyota dealer service. And that's exactly when they snap - and then what? I had car up on the lift, no oil, praying for the "ears" on it to hold, while I was un torquing it. Like we don't have enough trouble with plastic radiator tops and necks breaking off....
Old Aug 22, 2018 | 11:23 PM
cnnngbd's Avatar
cnnngbd
I found a YouTube Video. It’s in Chinese but you can clearly see the undercarriage.
https://m.youtube.com/watch?v=E9wHQd4LppM&t=871s
Old Aug 23, 2018 | 05:01 AM
WhatYaGot's Avatar
WhatYaGot
Thanks - that helped
semar
Sep 1, 2015 08:56 AM
99rx
RX - 1st Gen (1999-2003)
20
Mar 13, 2010 01:00 AM
TOLex168
Aug 31, 2009 04:41 PM
tomv
Hybrid Technology
Nov 18, 2008 08:14 AM
maximussp
Jun 4, 2008 04:06 PM
