How do you remove the plugs for these sensors. I have tried a lot of wiggling and pressure. There is some kind of blue tab is that what you push down on to slide it out? I can't seem to figure it out.
Anyone had luck getting the bottom sensor out? It feels like one tab at the top but it is such a PITA due to the weird angle behind the intake manifold on the NX..
Sometimes, the clip on the connector doesn't clear the tab on the sensor when you depress and pull, you may have to use a small flathead screwdriver or something similar to give you more leverage to lift the clip a little more or to pop the connector out. Very similar to the Toyota/Lexus ignition coil connectors (if those clips haven't already been broken), sometimes you may need to give them a little extra push. Don't use too much force though.
