NX - 1st Gen (2015-2021)
Loose gear shifter
Old Feb 22, 2017 | 03:53 PM
aekdb's Avatar
aekdb
Default Loose gear shifter
Anybody else got a loose gear shift? Not only is it slightly wobbly if I wiggle it around, but the entire thing twists left and right with just a little bit of force. I like to grip my right hand on it while driving, and lately if I grasp it hard, it will actually twist. It can probably be tightened but the leather will need to come off... ideas?
Old Feb 22, 2017 | 04:00 PM
d8168055's Avatar
d8168055
Ya, mine came like that as well. Squeeze the top of the leather boot and pull downward. There is a release tab somewhere, I forget if it's in the front or back, but it is easy to find. Turn the **** clockwise to tighten. Reattach the boot. Easy fix!
Old Feb 22, 2017 | 08:00 PM
aekdb's Avatar
aekdb
Hey thanks! I pulled down the leather like you mentioned and gave it a full 360 degree turn. That tightened it up. However the entire shifter still wobbles a little bit from the bottom. Maybe I'll have the dealer look at it.
Side note: in my opinion I wish the entire shifter was thicker. The thin metal rod just seems flimsy and not quality. (And clearly prone to wobbly/loose issues, or at least being thin amplifies it)
Old Feb 23, 2017 | 12:26 PM
tommytqt's Avatar
tommytqt
same problem. Nothing you can do beside putting in some teflon tape and try to twist it to the right position. Pull down the bottom leather then work out the top part.
avalon42
Sep 26, 2010 05:38 PM
Dx3
Sep 14, 2007 11:26 AM
JonCAGS300
GS - 1st Gen (1993-1997)
Aug 4, 2005 03:09 PM
StrmRdr23
RX - 1st Gen (1999-2003)
Jun 10, 2003 04:41 PM
