Turn Off Traction Control
Hello All,
I like to turn Traction Control OFF so that engine power doesn't cut out when it senses slippage (well, you need to know what you're doing since traction control is there for a good REASON). On the NX, pushing the squishy button will TC Off / ON. By default TC will be ON when speed hits above 35 mph (or so .. I'm guessing here) for safety reason (this works for almost all Toy/Lex vehicles).
What I am asking here is How to make TC OFF again after your speed is Below 35 mph (without pushing the button again)?
Example -
1- Push the TC button to turn it off, you will see the message saying so
2- Keep driving and TC is still Off until you hit 35 mph or higher - TC is back on
3 - Reduce your speed to BELOW 35 mph and your TC should be OFF - but no it is still on for the NX and if you want it to be off you need to push the button again.
Example -
Won't happen...it will always disable as soon as you go over 35mph and that's that.
If you want it to stay off, you can turn stability and traction both off by pressing and holding the button. It will stay off over 35mph and you can press again to re-enable. But no stability control isn't ideal.
I guess it works DIFFERENTLY comparing to the Tacoma and Tundra I had with Auto LSD
Eedo123
IS F (2008-2014)
Mar 19, 2016 10:11 PM
