NX - 1st Gen (2015-2021)
Question about Road Noise
Old Jun 5, 2015 | 11:46 AM
BKRS's Avatar
BKRS
Maybe I am sensitive and every individual has their individual perception of noise. Most impt for us to enjoy our ride
Old Jun 5, 2015 | 01:21 PM
corradoMR2's Avatar
corradoMR2
The pursuit of F
Coming from several Lexus including three past RXs which got quieter in the latest gen, the NX is as quiet as the the quietest Lexus I've owned, namely the current gen RX regarding road noise. However, wind noise at higher speeds is not as quiet thanks to the buffeting noise heard at higher speeds heard around the driver's side window (due to the single pane in the NX vs double-pane lamisafe glass in the RX).
In short, from my personal experience, the NX is quiet but echoing some of the comments, tires play a big role in road noise and although the Bridgestone Dueler H/L 33 are new tires, they are "sport street truck" summer tires, typically engineered with a focus on handling performance over all else.
I'm on 20" 255 wide Yokohama Parada Spec-X and the road noise is very quiet echoing all the positive reviews on this tire. I highly recommend this tire which even comes in the OEM NX sizes of 225/60/18 or 235/55/18.
http://www.tirerack.com/tires/tires....=Parada+Spec-X
Old Jun 5, 2015 | 08:04 PM
BKRS's Avatar
BKRS
May I check the switch over to Yoko Parada spec x do you feel the tyre noise is reduce immediately?
How would you rate the sidewall on this tyre versus stock? Do find the stock tyre pressure recommendation where the front and rear running exact psi or kpa the ride can be slightly on the jittery side from the rear when no passengers are carried when driving over small undulations in quick succession. "Probably also due to the shorter wheelbase on the NX"
I tried 260kpa front and rear, 250kpa front and rear, 230kpa front and rear and do feel my personal preference and to be at 240kpa front and 230 kpa rear for a balance fuel efficiency , driveability and slight improvement to the ride.
Old Jun 6, 2015 | 06:09 AM
corradoMR2's Avatar
corradoMR2
The pursuit of F
The Paradas are as comfy and quiet as the Michelin I had with the NX despite their lower profile. I can't compare to the Bridgestones.
I haven't tried a lower pressure at the rear but sounds like a good idea since I agree the rear can get a little "jumpy" over speed bumps for instance.
Old Jun 6, 2015 | 06:17 AM
tresmith00's Avatar
tresmith00
Originally Posted by D4V1D
We feel like our F Sport is REALLY quiet...and we have the summer tires.
As a side note, I don't think the NX is considered downsizing from the Q5. Q7 yes, but not the Q5. We parked them side by side and they are virtually identical in size.
I also have an F Sport with the summer tires. Even though I feel that the car could be quieter, I realize that most of the noise is road noise from the tires. when I'm on the phone people have commented on it.
I'm looking forward to changing the tires later in the year and putting on much quieter and more fuel efficient all season tires.
Old Jun 6, 2015 | 06:18 AM
15RC350F's Avatar
15RC350F
What are your "summer tires" and what will the all-season ones be?
Old Jun 6, 2015 | 06:23 AM
leej865's Avatar
leej865
The 'summer tires' are the Bridgestone Duelers...and I do not think they are noisy at all.
Old Jun 7, 2015 | 04:19 AM
tresmith00's Avatar
tresmith00
I also the bridgestone duelers.
I'm looking to put on the bridgestone ecopia's. They are a LRT that's supposed to help with mpg. They are extremely quiet.
I had put them on my previous car, camry se, swapping out the worn sport tires. And boy did they make a difference. The ride was much, much quieter and I got about a one to two miles extra on my mpg.
I'm averaging about 24 mpg now and I figure with the ecopias I should get north of 25 mpg...plus a better, quieter ride.
Old Jun 7, 2015 | 04:21 AM
tresmith00's Avatar
tresmith00
It depends on the roads too. I live in Atlanta and the roads need work.
Old Jun 7, 2015 | 06:58 PM
DLKC's Avatar
DLKC
Thanks for the heads up. Heard good reviews on them. in fact even the michelin latitude sports 3 which comes with the macans seems to be pretty quiet too. Will definitely give it a try when in due course.
Test drove the F-sport and it was noisy. (Coming from an 2IS and 4GS with Michelin tires), I think the Dueler is the issue. We plan to order the F-sport this week, will specify that the Dueler be replaced by the Michelin and we do not mind paying the extra cost.
Old Jun 7, 2015 | 08:59 PM
BKRS's Avatar
BKRS
The Fsport comes with 235/55/R18 rather than 225/60 R18 therefore contributes to marginally higher road noise than the executive or Luxury version.
The road noise improves marginally once the tyre scrubs in after a couple of hundred KMs.
Old Jun 8, 2015 | 09:14 AM
aIRpeACE's Avatar
aIRpeACE
summer tires are softer and absorb more road noise and bumps
BSW13GS350
Jan 19, 2019 11:45 AM
1halifax
Mar 15, 2018 07:02 PM
jjskywlker
Aug 13, 2013 04:44 AM
dojoman
Aug 5, 2013 05:53 AM
GREED777
Hybrid Technology
Aug 23, 2011 03:48 PM
