NX - 1st Gen (2015-2021)
Reduce Engine Power 42k after changing spark plugs
Old Jan 9, 2025 | 07:30 PM
baowser210's Avatar
baowser210
6th Gear
I replaced the spark plug in that cylinder, but to be on the safe side, I actually brought some OEM parts from Lexus and replaced all my spark plugs.
Old Jan 9, 2025 | 08:06 PM
narci's Avatar
narci
awsome, thanks for this. I so hope it’s not the same issue as the Tacoma folks. Burnt valve that require cyclinder and head replacement.
Old Jan 10, 2025 | 12:38 AM
Lexicon1's Avatar
Lexicon1
Cylinder mis-fire can also be igniter issue.
You can swap locatoin of the igniter to locate which one is defective, if that is not it, there is a possibility of a head gasket issue....but hopefully that is not the case here.
Note that the original poster did use fuel injection cleaner as a possibillty of an injector issue.....
Keep us posted
Old Jan 10, 2025 | 07:13 AM
narci's Avatar
narci
Keep us posted
thanks Lexicon. I cleared the code and put in half a bottle of redline fuel injector cleaner in 3/4 of a tank. Going to run the tank, fill with premium gas and use the other half.
So far, first few trips, still a slight stutter sometimes, no cel yet.
Old Feb 3, 2025 | 11:16 AM
gompka's Avatar
gompka
P0303 was ignition coil for me. First part to go after 86k
Old Feb 3, 2025 | 03:26 PM
Lexicon1's Avatar
Lexicon1
Narci,
If it comes to fuel injection cleaner, my go to is Royal Purple Max cleaner... works for me.
Important to follow the correct dilution per instructions or even make it more concentrated to get the job done.
Good luck w Troubleshooting...
Old Feb 3, 2025 | 05:04 PM
narci's Avatar
narci
Narci,
thanks. Tried Redline and Toyotas own injection cleaner. No go. Car still rough, stutters and misfires at times. P11EE still shows up after a day or so after every time I clear it.
Techstream stated code is an air fuel imbalance (port). Had all 4 port injectors replaced. I could have done 1 but might as well do all 4 since the labor is about the same. Car runs like new now.
User 122922
Jun 15, 2022 01:11 PM
714is300
May 24, 2020 11:56 PM
PepperERev
Oct 23, 2014 03:01 PM
cheez
Apr 20, 2010 05:43 AM
scottmcc
Apr 14, 2008 07:11 PM
