AZ AMPS< SUBS, and more AMPS!
Old 06-05-13, 11:50 AM
Knuckleup
Knuckleup's Avatar
Default AMPS< SUBS, and more AMPS!
I have 2 great condition JL audio 300/2 amps for sale.
$230 cash, no trades.
Differential-Balanced Input Topology: (1 pair of Inputs)
On-board Crossover: fully variable (50Hz - 5KHz), selectable-slope LP (12 or 24 dB per octave)
Preamp Output: 2-channel (full-range, LP or HP)
Speaker output connections: accepts up to 8ga. wire
+12V and Ground connections: accepts up to 4ga. wire
Specifications:
Rated Power (stereo): 150W RMS x 2 @ 1.5 ohm-4 ohm
(11V-14.5V)
Rated Power (bridged): 300W RMS x 1 @ 3 ohm-8 ohm (11V - 14.5V)
THD at Rated Power: <0.03% @ 4 ohm
S/N Ratio: >108.5dB below rated power
Frequency Response: 5 Hz-30KHz (+0, -1dB)
Damping Factor: >200 @ 4 ohm per channel/50 Hz
Input Range: switchable from 200mV-2V RMS
to 800mV-8V RMS
Dimensions: 13.4"L x 9.25"W x 2.36"H
I have 2, still in the box JBL 10in subs for sale. $85 each. These are in perfect working order, still have all the original packaging.
http://www.crutchfield.com/S-nv5Y7sD...-GTO1014D.html
I have a 12in kicker cvx sub in a ported box in brand new condition.
$400 cash, no trades.
http://www.kicker.com/comp_vx
I have a like brand new condition JL audio amp for sale. 250/1v2.
$220 cash, no trades.
http://www.jlaudio.com/250-1v2-car-a...plifiers-98081
2 high end MB quart crossovers for sale. Model # QXD 216. They are in perfect condition.
$120 for both. Cash only, no trades.
LOCAL PICKUP. I would like to sell this locally to avoid shipping.
I can be reached via txt @ 352-346-4590
Attached Thumbnails AMPS&lt; SUBS, and more AMPS!-img_20130604_134440.jpg   AMPS&lt; SUBS, and more AMPS!-img_20130604_134915.jpg   AMPS&lt; SUBS, and more AMPS!-img_20130604_134921.jpg   AMPS&lt; SUBS, and more AMPS!-img_20130604_134947.jpg   AMPS&lt; SUBS, and more AMPS!-img_20130604_135001.jpg
Knuckleup is offline
Old 06-05-13, 11:53 AM
Knuckleup
Knuckleup's Avatar
Pic of the kicker sub and box.
ls400kyl
05-01-19 02:39 PM
Shaft350
03-25-08 12:14 AM
Lexus GS3
12-09-07 07:52 PM
elclassico
01-22-04 12:36 PM
Quick Reply: AZ AMPS< SUBS, and more AMPS!
