help... pass side rear window
Old Sep 17, 2003 | 04:39 PM
lexforlife's Avatar
lexforlife
Default help... pass side rear window
my pass side rear window all of a sudden today stopped working. does not go up or down from master switch or door switch.. i hear no motor going and there is no drain on battery when i depress either switch
what do you think it could be , all other windows work fine
Old Sep 18, 2003 | 03:31 AM
VVT-i's Avatar
VVT-i
You have to remove the door panel and to see if you get any voltage at the window motor connector. If you get 12 volts when you press the window switch, then your motor may be bad.
Old Sep 19, 2003 | 06:16 AM
ChuH's Avatar
ChuH
Dang!!! Just found out my rear passenger window doesn't move!!! Rarely open the rear windows.
Boy three different problem in one month. (1) popping sound while braking and turning - Lexus is going to replace the front calipers (2) grinding sound while lightly accelerating from standstill - Lexus can't figure this out yet; schedule service next week. And now (3) rear passenger windows does not move.
2-1/2" years and 22000 miles. Kind of disappointed but glad it is still under warranty.
Chu...
Smitslex
Jan 20, 2014 06:26 PM
turtle54
Jul 25, 2013 02:30 PM
tbm5690
May 10, 2013 06:53 AM
tianh
Apr 11, 2012 07:32 AM
Move Over Rover
Jun 23, 2003 06:59 PM
