broken electrical connector locking tab solution
Old Oct 4, 2019 | 09:09 AM
reozone's Avatar
reozone
Default broken electrical connector locking tab solution
I thought I would share this with the forum under maintenance, since it applies to all models. I just finished replacing the starter, again, on my ls430 (another post) and had concerns about several engine electrical connectors whose locking tabs had broken off due to age. I wanted a way to hold the connectors to the sensor/component so I wouldn't have to worry about it vibrating loose over time. An especially important consideration when said connector is in a normally inaccessible location. The solution I came up with was to use something called Silicone Rescue Tape, which I found in the plumbing section of our local hardware store. It electrically insulates and, more importantly, resists temperatures up to 500 F. This actually fuses to itself, so, once wrapped around a connection, the only way to get it off is to cut it. I did a total of 4 connectors and must say I am very impressed with the results. I'm curious to know what other solutions the forum members might have come up with.
Johnny62
Jun 25, 2019 01:02 AM
wbzautocus
12
Jan 26, 2016 10:31 AM
tcr101
Jun 8, 2015 03:28 PM
werewolf
Mar 29, 2010 06:26 AM
Greydog
Apr 20, 2005 06:34 PM
